Drivetrain Gauge install help, cross post
Old Jan 15, 2004 | 09:07 AM
ColoradoMark's Avatar
ColoradoMark
I've finally collected all the pieces for my gauge install. The SPA gauge I'm installing has two 4 pin connectors that I need to fish through the firewall. Those of you that have installed boost gauges and other gauges (or just fished something through the firewall) I need some advice:
Is the best place to go through the firewall at the thick rubber piece above the pedals and behind the brake vacuum reservoir, where a large red cable and a wire bundle pass through? Do you think I can fit the ~1/4 inch connectors for the sensors through this piece?
BTW, here's what I'm installing: SPA Dual oil pressure/oil temp gauge, autometer boost gauge, ALTA gauge pod, Intercomp lap timer. I'm tapping a hole in the oil filter canister for the temp gauge. I ordered a fitting from BMP to go where the oil pressure switch is, I'll run a braided hose up a foot or so from that and remote mount the pressure gauge sensor on another fitting. I'll take pics as I go and try to create a some semblance of an install FAQ.
Thanks!
Mark
Old Jan 15, 2004 | 10:06 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
that is where you will want to run through the fire wall. that is where mini has the rally lights run through. good luck, photo's when done!!!
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
squawSkiBum
Oct 2, 2015 09:21 AM
kpl
Aug 11, 2015 04:52 AM
