Drivetrain Opinions Wanted - Best and most efficient boost sources for a mini
Old Mar 28, 2011 | 07:09 PM
  #26
Minian's Avatar
Minian
Originally Posted by llabmik2
TVS=Twin Vortices Series. Its the new style of roots supercharger.
Give Jan a call he will tell you what the retail is on the Rotrex system.
Thanks for your reply.
I've PM'd Jan a couple of times over a few months, but he doesn't answer.
Old Mar 28, 2011 | 07:14 PM
  #27
Revolution Mini Works's Avatar
I've went thru my PMs back to Sept of 2010.........not one from you in the inbox?
feel free to call, pm or email me..........
Old Mar 28, 2011 | 07:38 PM
  #28
minimarks's Avatar
minimarks
Thanks for your reply Minimarks.
__
Your welcome!
PS: Don't hesitate to give Jan a call, if he doesn't answer just leave a name and message and he'll call you back....heck I should know, I'm bugging him with questions all the time and he's still picking up the phone..lol
Old Mar 28, 2011 | 07:46 PM
  #29
llabmik2's Avatar
llabmik2
Yep no problem. Forget the PM's I would just call Jan. EASY guy to talk to. Whatever questions you have he will have a answer for them.
Old Mar 29, 2011 | 06:19 AM
  #30
JumpingJackFlash's Avatar
JumpingJackFlash
uuuuuuug!!!!
All those acronyms. What is TVS, and most importantly the estimated cost of the Rotrex Kit from RMW?
Old-school superchargers had two-bladed rotors and were straight in design. Later designs have three-bladed rotors with a 60-degree twist. The TVS setup from Eaton has four-bladed, teflon-coated razor-edge blades with a 160-degree twist. You can read more here: http://www.eaton.com/EatonCom/Produc.../TVS/index.htm.
Chevrolet was one of the first companies to use this design, as it comes on their supercharged ZR-1 Corvettes from the factory.
Old Mar 29, 2011 | 06:41 AM
  #31
here's a pic of the TVS 1320 that I crammed into my car.
The blower was awesome, did exactly what Eaton said it would do. The ONLY problem with the 1320 is it is too big to fit as a stock replacement without having to modify just about everything. There will be a TVS900 this YEAR.... (yes, it's FINALLY coming) and we will be making a kit with it.
Having tested the product it will do what WE WANT to do with the blower and do it reliably
Old Mar 29, 2011 | 08:11 AM
  #32
JumpingJackFlash
Did a little research. Cheapest price I see on the market for current TVS designs (in a larger size) is $6K. Hoping the R900 will be cheaper than that.
Here's a PDF file for reference as well: http://www.engine-expo.com/forum_200...rt_walling.pdf.
Old Mar 29, 2011 | 08:22 AM
  #33
my guess would be the $3500 range
Great article by the way............shows why superchargers are superior in most cases. As I said before, the TVS is an awesome s/c , the TVS1320 wasn't suitable because of the costs to make the kit. As for "stupid" power at ANY INSTANCE...........it was the most amazing Mini I have ever driven and I've driven every type of Mini out there.
Old Mar 29, 2011 | 09:21 AM
  #34
llabmik2's Avatar
llabmik2
What about the 1040 Jan? Would it require lots of modification to fit also? Its a little bigger then the 900 and a little smaller then the 1320.
By the way. I got to try out the OSGiken a little in the canyons behind my house today. Night and day to the open diff. I can stay on the throttle without pushing through. What really surprised me was that it broke traction and it just kept pulling the corner.
Old Mar 29, 2011 | 09:30 AM
  #35
from my sources at Eaton, it doesn't look like the 1040 may get produced this year so we will go with what's available and what will actually fit
the OS is awesome, no doubt
Old Mar 29, 2011 | 09:36 AM
  #36
llabmik2's Avatar
llabmik2
DAMN YOU EATON!!!!!!
Do you think the TVS900 will make about as much as the small Rotrex, with a better curve? The Rotrex comes on like a turbo. High hard and fast. I figure the main difference is going to be whats down low.
Old Mar 29, 2011 | 12:30 PM
  #37
my guess would be tons of wheelspin down low
should be about 300whp maybe 320whp ringing the guts out of it
Old Mar 29, 2011 | 06:53 PM
  #38
davisflyer's Avatar
davisflyer
Put me on the list.......
Old Mar 29, 2011 | 07:38 PM
  #39
JumpingJackFlash
I thought you might like that file. I've been a huge fan of the TVS design ever since it came out.
Old Mar 29, 2011 | 08:53 PM
  #40
Longboard Mini's Avatar
Longboard Mini
Here is an example of what the "small" Rotrex can do
Longboard
Old Mar 30, 2011 | 06:19 AM
  #41
JumpingJackFlash
Longboard
That's some good numbers. Especially the torque band peaking at 6000 RPM!!!!
Old Mar 30, 2011 | 06:22 AM
  #42
That's why it excels so well on the track
That and th cool outlet temps
Old Mar 30, 2011 | 07:53 AM
  #43
llabmik2's Avatar
llabmik2
Cool outlet temps
That's a bit of a understatement I think. After the full throttle ride in the "low power" yellow Mini, the "hot side" was almost the same temp as the discharge side. I would say COLD outlet temps lol.
xpunisherx
Aug 10, 2015 10:50 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
kwijmbo
Aug 5, 2015 09:00 PM
