Drivetrain Assistance on Starter Performance Mods...
Old Feb 9, 2012 | 11:53 AM
  #26
axleR56's Avatar
axleR56
Originally Posted by steptimeeditor
Forgive the, (what I'm sure sounds like a) stupid question. I am interested in the Torque Arm Bushing mod and wanted to know how many I need. Just one? Thanks!
Just one, they come in a pair (one piece goes on the right side of the stock bushing, one goes on the left)
Old Feb 9, 2012 | 12:30 PM
  #27
steptimeeditor's Avatar
steptimeeditor
Thanks!
Old Feb 9, 2012 | 12:46 PM
  #28
gallopingford's Avatar
gallopingford
Do you have any pictures documenting this? I installed a DoS CAI on my 2011 MCS almost a year ago and haven't had any issues that I'm aware of but I am curious to learn more about the issue you are having and see if this may be something that I could be suffering from and now know about
I don't have any pictures of this since. Since then I have gotten the tube replaced. Half of the cause was from the remaining oil in the tube (from an over oiled Alta intake). It caused the tube to just slide off the throttle body.
Old Feb 10, 2012 | 09:04 PM
  #29
Phx JCW's Avatar
Phx JCW
How come I never hear anything about the water to air Intercooler from DoS? I know it's pricey, but ??
Old Feb 10, 2012 | 09:46 PM
  #30
Bilbo-Baggins's Avatar
Bilbo-Baggins
Probably because it isn't worth the money. Most water to air ICs can delay heat soak a little while but eventually the water temp increases faster than it can be cooled and then you just loose power. A good air to air IC can drop temperature faster after heat soak. All it takes is about 30 to 40mph to get enough air flow to start cooling things off.
The absolute best, first mod has got to be a "Light-In-Sight" device http://www.lightinsight.com/ every MINI should have one.
Old Feb 11, 2012 | 01:30 PM
  #31
Mini'mon's Avatar
Mini'mon
Intercooler efficiency really depends on how the system is designed. Our system doesn't experience the issues that Bilbo is mentioning. We did our homework for flow rate, heat exchange efficiency, and keeping the overall volume of coolant required for the W2A-IC as low as possible.
The main reason that you don't hear that much about the DoS R56 W2A-IC is that A2A-IC's outsell our W2A-IC. They're a higher ticket item and pocketbook is king in this time of economic turnaround.
-Clint
AvianMan
17
May 17, 2019 07:25 PM
Sep 4, 2015 02:12 PM
Aug 25, 2015 07:11 AM
Aug 21, 2015 11:25 AM
