Drivetrain Intercooler Cover
Old Jan 10, 2004 | 05:20 PM
resipsamcs's Avatar
resipsamcs
I hope I am not the only MCS owner who would like to see a good-looking aftermarket intercooler cover, maybe a carbon-fibre or aluminum looking cover that would dress up the engine compartment. Some added functionality like the Alta with diverter would be nice as well. I like the look of the JCW, but the stock black plastic cover looks chintzy. Anybody else? Any vendors with plans?
Old Jan 10, 2004 | 06:09 PM
zminiman8's Avatar
zminiman8
Proper prep work and a can of spray paint ( whatever color you choose) works wonders for a stock intercooler cover.
Old Jan 10, 2004 | 07:13 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Here is the stock cover with a hand painted "S" and metallic blue accent spray painted (heat resistant paint)
Old Jan 10, 2004 | 07:33 PM
BFP's Avatar
BFP
We are currently working on a VERY nice Carbon Fiber intercooler cover that is not just an OEM shape replacement part. It's been designed and styled to flow very nicely with the engine bay, and it adds functionality by better forming the seal with the hood scoop foam (look up).
It's going to go very nicely with our soon to be released CAI (which will have 3 variations - all including Carbon Fiber).
-Dan
If you have any questions, feel free to ask at dan@benferperformance.com
http://www.benferperformance.com
Old Jan 10, 2004 | 08:14 PM
resipsamcs's Avatar
resipsamcs
Minihune - Your custom cover looks great!
Dan - I look forward to seeing your product (hint hint). I would love to see photos when available. Is there an estimated price or price range you can share at this time?
Old Jan 10, 2004 | 08:17 PM
BFP's Avatar
BFP
No price or est. date as of right now. We are in the process of making the mold, after which production can begin almost immediately (considering everything going smoothly with the mold).
I will have pics, pricing, availability, etc. soon.
-Dan
Old Jan 12, 2004 | 12:08 AM
jmoser's Avatar
jmoser
Nice Job Minihune-I love seeing what people can DO....
off topic, but what strut is that you have installed? (seen it advertised but not installed..can't remember) Looks good too...
Old Jan 12, 2004 | 08:56 AM
Moorlockx's Avatar
Moorlockx
Half a world away, some people just think alike! :smile:
Old Jan 12, 2004 | 09:04 AM
Nobull60's Avatar
Nobull60
>>-Dan
Just make it affordable so they sell. Someone has one for sale for over $450.00 if I remember correctly. Plain ol' rip off.
Old Jan 12, 2004 | 10:14 AM
BFP's Avatar
BFP
>>>>-Dan
Yeah, I've seen that one. It's also an OEM replica, not a new design. Ours will be much less than that.
-Dan
Old Jan 12, 2004 | 11:34 PM
minihune's Avatar
minihune
Moorlockx,
I like your red and reverse emphasis paint accent of your IC cover! I did paint the various covers as you did including my Brake fluid cover. My picture is actually and old one. I got the Pilo ignition upgrade and painted the coil as well.
jmoser,
The front tower strut brace is the BMP aluminum which is about 3.5 pounds and about $240.
There is often a debate over how much the strut brace actually can help performance.
From an appearance point of view it is attractive, easy to install, easy to keep clean but it does cramp some intake boxes-my madness intake box needed a notch cut into it so the strut bar could fit.
Be aware that some strut bars are not aluminum, can be powder coated steel (heavy) and still cost over $200.
http://www.webbmotorsports.com/suspension.php
Old Apr 24, 2004 | 10:41 AM
CornOnTheCob's Avatar
CornOnTheCob
What was the process for painting those intercooler covers? I'm assuming there's more to it than just spray painting on some heat-resistant paint.
Old Apr 24, 2004 | 11:08 AM
minihune's Avatar
minihune
You can get a body and paint shop to paint your cover with the OEM paint. Here's a picture of that with a keychain "S" doublesided taped to it.
If you paint your dash or door parts you can add the IC cover at the same time for pretty cheap.
Or if you look at my earlier post you'd see my own partially painted cover which I did myself. Hand painted enamel "S" in silver and red with Blue metallic indentions spray painted. You can do a light sanding after masking with tape and then apply primer Duplicolor Metalcast Ground coat (provides uniform base to plastic) a few coats then Duplicolor Metalcast metallic blue color paint (heat resistant, anodized high gloss finish). I did not clear coat but I did wax the surface. Be careful that the paint has dried thoroughly before installing the cover as the bolts will squash the paint if you tighten them down hard. Also the bolts do come loose easily so try some lock tite.
The four bolts are black but you can paint them with the same blue paint to get them to match the cover.
Tighten them down gently by firmly.
_________________
Aloha Hawaii
Old Apr 24, 2004 | 03:09 PM
chrisfb1's Avatar
chrisfb1
It is an old picture i took long time ago.
I painted everything myself.
I was not very experienced so i did not do a very good job.
I bought metalic paint and paint some covers and tops.
I did not have the red paint so i did not paint the S in red.
I'm waiting for the new paint come in so i can play around a bit more.
Old Apr 24, 2004 | 03:41 PM
speltzer's Avatar
speltzer
Try the new Krylon "fusion" paint. It is designed to adhere to plastic surfaces. 32 colors available.
IQRaceworks
Jul 15, 2022 05:51 AM
madmax88
Aug 21, 2017 07:07 PM
blackie
Oct 2, 2015 07:41 PM
Aug 11, 2015 09:01 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
