Drivetrain ALTA Billet 56 MCS Turbo sneak peak....
Old Jan 7, 2011 | 09:13 AM
  #51
dunphyj's Avatar
dunphyj
Originally Posted by czar
Just because we have a KO3 turbo, and other manufacturers use them, all are not equal.
For example have a look at the compressor housing outlets on many of the similar KO3 turbo's to our KO3 compressor housing, then you need to look at
the compressor maps, to plot where the efficiency is, in comparison to our KO3 compressor map!
It is not as simple as saying, ooh looky a KO3 off of a VW/Audi/Peugeot/Citroen and presuming it's the same, it is NOT.
Never said it was i was just responding to the earlier mention of K03s... considering i've been working on turbo cars for a while, i know that they're not the same. similat but not the same...
Old Jan 7, 2011 | 09:15 AM
  #52
dunphyj's Avatar
dunphyj
Originally Posted by Creeve
No worries, I was just kidding around.
same here... thought you'd know that Czar from all the other threads we've commented in :P
Old Jan 7, 2011 | 10:22 AM
  #53
czar's Avatar
czar
Sorry guys, I just get a little frustrated.
Old Jan 7, 2011 | 10:40 AM
  #54
dunphyj's Avatar
dunphyj
It's cool!
Old Jan 7, 2011 | 12:11 PM
  #55
MatthewMateo's Avatar
MatthewMateo
Thanks guys.
Oh, and Creeve, nice sarcasm.
Old Jan 11, 2011 | 12:43 PM
  #56
Raymazing's Avatar
Raymazing
I really like my GT28RS. If youre starting from scratch and havent purchased downpipes or charge pipes etc. that is. it wouldnt be a whole lot of difference in price with capability of making 400hp. Im on boost at 3100 max by 4 at 17psi right now(1.2 bar wastegate spring). Profec B boost solenoids are on backorder at Greddy. plus that pesky map sensor crap.
Old Jan 11, 2011 | 08:48 PM
  #57
Cawtou's Avatar
Cawtou
something to look forward to.
btw i live in cali so carb is always an issue. do you think there will be problems when going thru smog check and the like?
Old Jan 16, 2011 | 02:10 PM
  #58
jsyang15's Avatar
jsyang15
can't wait for this and AP stage 4
Old Jan 17, 2011 | 09:50 AM
  #59
ALTA_Chris's Avatar
ALTA_Chris
It depends on the other parts that you have on the car. Usually with this turbo, you would want to get a new turboback and intake at least, which won't be CARB approved.
Old Feb 4, 2011 | 06:26 PM
  #60
ENGINE 58's Avatar
ENGINE 58
any new news on this turbo?
Old Feb 7, 2011 | 04:57 PM
  #61
ALTA_Chris's Avatar
ALTA_Chris
Right now the plan is for the turbo to come out in March. If you are interested in the turbo earlier though, send us a PM, thanks!
Old Feb 8, 2011 | 09:33 AM
  #62
tcowden's Avatar
tcowden
Chris,
What kind of material testing have you all done on this? Are you relying on the stock material used or have you done structural testing after the piece has been cut?
Just the material/mechanical engineer in me being curious. I'd hate for a vane to fracture and shear under high boost.
Cheers,
Tom
Old Feb 8, 2011 | 12:31 PM
  #63
ALTA_Chris's Avatar
ALTA_Chris
Tom,
Thanks for your question! The wheel that is going to be used in the turbo is made of the same material that is currently being used in many turbos being used for other applications. We worked closely with a well known turbo manufacturer to apply this billet technology to a Mini turbo, so you don't have to worry!
Old Feb 13, 2011 | 06:29 AM
  #64
guazzo's Avatar
guazzo
sorry but how does it cost the modified Alta turbo billet?
Old Feb 14, 2011 | 02:01 PM
  #65
ALTA_Chris's Avatar
ALTA_Chris
Guazzo,
The price for the turbo is $2,200. Thanks!
Old Feb 14, 2011 | 02:47 PM
  #66
Bigprfed22's Avatar
Bigprfed22
Selling the wheel independently!?
Old Feb 14, 2011 | 03:20 PM
  #67
guazzo's Avatar
guazzo
Originally Posted by ALTA_Chris
Guazzo,
but you give me a new turbo or you tuned mine? now i'have on my R56s the full alta exhaust and the ecu remapped, how much hp could be increased? thank you very much!
Old Feb 14, 2011 | 06:01 PM
  #68
unplugged's Avatar
unplugged
Guazzo,
This price is fir a swap? Or a straight purchase? Tks
Old Feb 25, 2011 | 05:48 PM
  #69
grkm's Avatar
grkm
still no answer ?
Old Feb 28, 2011 | 02:46 PM
  #70
ALTA_Chris's Avatar
ALTA_Chris
I'm sorry, we aren't going to sell the wheel just by itself.
The new turbo can do 280 WHP potentially. We are still working on the tune.
The price will be $1,200 to do your turbo, as long as it checks out to be OK.
Originally Posted by grkm
still no answer ?
Sorry for the delay, NAM hasn't been notifying me of replies.
Old Feb 28, 2011 | 04:13 PM
  #71
Cawtou's Avatar
Cawtou
Alta Chris: Thanks for the info, also I was wondering how much more hp i can make if i only change the turbo and keep my stock exhaust and intake.
Old Feb 28, 2011 | 04:25 PM
  #72
LASRGUY's Avatar
LASRGUY
Any MAP sensor issues?
Will the MCS MAP sensor be a limitation in taking advantage of this turbo? My car has a ram air intake and with the standard stage 3 map I was getting getting MAP sensor limit errors. Jeff customized a map for me which solved the problem for now but I'm wondering if a bigger turbo would need the JCW's MAP sensor which has a higher limit.
Old Feb 28, 2011 | 04:54 PM
  #73
ALTA_Chris's Avatar
ALTA_Chris
If you keep stock everything, the new turbo will be able to give you at least what the JCW turbo will. We're expecting most customers to install the turbo after having a turbo back exhaust and an AccessPORT at least.
We are working on that. I'm not sure what Jeff has up his sleeve, but we will be able to figure something out!
Old Mar 13, 2011 | 07:29 AM
  #74
ThePro's Avatar
ThePro
Interesting, I just put a 2560 into my MC and it's been a blast =)
Old Mar 13, 2011 | 01:43 PM
  #75
MotorMouth's Avatar
MotorMouth
how and who tuned it?
