Drivetrain ALTA Billet 56 MCS Turbo sneak peak....
Old Mar 13, 2011 | 08:48 PM
  #76
ThumperMCS's Avatar
ThumperMCS
Originally Posted by MotorMouth
how and who tuned it?
Typical fashion for someone who's running a GT28RS or GT25....
"I just installed a GTxxxx and its running great!"
And then that will be the last you ever hear anything from them or their "project"
Old Mar 14, 2011 | 04:43 PM
  #77
MotorMouth's Avatar
MotorMouth
I don't expect a coherent response.
especially after looking over his post history.
Old Mar 21, 2011 | 07:25 PM
  #78
TheMINIPartStore's Avatar
TheMINIPartStore
Any new ETA on the turbo? I'm ready to spend some money.
Old Mar 21, 2011 | 07:50 PM
  #79
ThumperMCS's Avatar
ThumperMCS
so its been a few days and still nothing, as expected
I have a brand new JCW turbo for you then...
Old Mar 21, 2011 | 10:53 PM
  #80
redzmini's Avatar
redzmini
subscribed
Old Mar 22, 2011 | 05:16 PM
  #81
ALTA_Chris's Avatar
ALTA_Chris
The new turbo is still about 3 weeks away, sorry! We will update the thread once it's ready!
Old Mar 28, 2011 | 04:15 PM
  #82
raindizzle's Avatar
raindizzle
Old Apr 20, 2011 | 10:16 AM
  #83
raindizzle's Avatar
raindizzle
Alrighty so what's the new time frame on this since it's been more than 3 weeks?
Old Apr 20, 2011 | 11:48 AM
  #84
ALTA_Chris's Avatar
ALTA_Chris
Very very soon raindizzle! If you're ready to order it, give me a call, thanks!
Old Apr 20, 2011 | 12:20 PM
  #85
BooHAHA's Avatar
BooHAHA
saving my pennies
Old Apr 24, 2011 | 12:25 PM
  #86
tvanhouten's Avatar
tvanhouten
Perhaps Alta could run some sort of Summer special where a person could send their turbo in for the rebuild, then Alta sends you back the upgraded turbo with an AP unit for one nice price...
Old Apr 24, 2011 | 01:57 PM
  #87
ENGINE 58's Avatar
ENGINE 58
yeah i wouldnt mind swapping my jcw turbo and getting the ap at the same time
Old Apr 24, 2011 | 04:26 PM
  #88
BooHAHA's Avatar
BooHAHA
Bundle Package!
Old Apr 25, 2011 | 04:03 PM
  #89
chakraj's Avatar
chakraj
Just two more weeks
Old Apr 25, 2011 | 04:44 PM
  #90
minimike21's Avatar
minimike21
i like the bundle package!!
Old Apr 26, 2011 | 11:49 AM
  #91
ALTA_Chris's Avatar
ALTA_Chris
We can bundle parts together if you guys are interested, just give us a call. We aren't able to discount the AP, and probably not much on the turbo, but if you're looking for multiple ALTA parts, we can do something.
Old Apr 26, 2011 | 03:10 PM
  #92
countryboyshane's Avatar
countryboyshane
What happened to the MAP sensor update? Does the MAF sensor need to be changed as well?
Old Apr 26, 2011 | 04:29 PM
  #93
J_'09s's Avatar
J_'09s
+1
Old Apr 26, 2011 | 04:45 PM
  #94
ALTA_Chris's Avatar
ALTA_Chris
So far we haven't found a way to replace the MAP sensor in the S. We've been able to make about 20 PSI with the new turbo on the S, which gives it a ton of power over the stock turbo. We will be posting up dynos soon.
Old Apr 26, 2011 | 05:55 PM
  #95
MotorMouth's Avatar
MotorMouth
aren't stock turbos hitting 21 already?
Old Apr 26, 2011 | 06:07 PM
  #96
///Mflossin's Avatar
///Mflossin
Ditto that. I thought guys were hitting 20 now???
Old Apr 26, 2011 | 06:19 PM
  #97
DneprDave's Avatar
DneprDave
Wouldn't a resistor in the signal wire to the ecu fool the ecu into thinking the boost was less than it is? Pick the right resistor and the ecu would think that 25 psi was 19 psi.
Dave
Old Apr 26, 2011 | 06:21 PM
  #98
Bigprfed22's Avatar
Bigprfed22
Dave
Old Apr 26, 2011 | 06:23 PM
  #99
DneprDave's Avatar
DneprDave
Don't just shake your head, tell me what I'm missing!
Dave
Old Apr 28, 2011 | 11:37 AM
  #100
ALTA2's Avatar
ALTA2
Manufacturer
For sure people are and the issue issue is you can't really go way past 20psi. Chris was giving the relative boost people most likely see. Basically 22psi is the actual limit where cut occurs (some variables are there because of ATMP). On MCS's, you really only bump this pressure for a second and the boost falls off. So rarely do customers have the hard boost cut occur.
So when tuning the Billet 56 on our MCS, 20psi is all i felt safe running because it holds boost so much better than the stock turbo that i was constantly bumping off the MAP sensor limit when running 21psi. It appears that there are two limits, one is the boost limit, the other is an internal MAP sensor voltage limit. I can remove the boost limit, but the MAP voltage limit is what i can't. The solution is to add new tables for the JCW maps sensor scaling (or other map sensors), but that is a ways off.
Dave
Nope, that is because the sensor stops reading at 22psi~. Adding a resistor messes up load and causes drivablity issues. This is just like installing JCW sensors in the car (lower voltage for same boost) but they don't run well at all with them installed.
If anyone is interested in the turbos, give us a call and we can spill the beans!
