Drivetrain Cooper S - worth upgrading to JCW brakes or not?
Old Nov 28, 2010 | 04:32 PM
  #26
etalj's Avatar
etalj
I would probably save my money and just upgrade the rotors, lines, fluid and pads. Use the change to buy a suspension upgrade. Far more worth your while.
Old Nov 28, 2010 | 09:04 PM
  #27
PoktRokt's Avatar
PoktRokt
Originally Posted by czar
your still missing the point, so you spend $1K on your JCW brake kit, you've achieved nothing, in regards to uprating brake performance!
You've still got stock rotors and pads, that offer nothing more than the stock Cooper S, regarding heat dissipation!
So you've now to look at purchasing grooved performance discs and a pad to suit your track set up, for your JCW brake kit, you will now have spent approaching $2K to get your JCW brake kit to perform as well as a good set of pads and discs fitted to your stock Cooper S set up, which would cost approx $700!
I track my S and use stock S calipers, stock sized S discs, cryogenically frozen with 48 1/4 moon shaped grooves per front discs, and carbotech XP10 front and XP8 rears, stainless hard lines and Castrol SRF fluid, and can brake harder and deeper than most, a friend has a JCW, and comes knowhere near my braking points, when on track!
Are the cooper s brakes good enough for autocross or would upgrading the rotors/pads/lines/fluid make a big difference? And could all these things be done for less than $1000.00? Thanks
Old Nov 28, 2010 | 09:12 PM
  #28
DneprDave's Avatar
DneprDave
The stock brakes on my car are the best I've ever had. How good do you want? Try tracking it with the stock brakes, if you think you need more, get 'em.
Dave
Old Nov 28, 2010 | 10:44 PM
  #29
dunphyj's Avatar
dunphyj
MY GOD YES! you can fully upgrade rotors, pads, lines and fluid for about $650...
i personally have TSW Rotors all around, Ferodo DS2500 pads front, stock rears, Helix/IrelandEngineering SS Lines, and Superblue fluid... swapping to Castrol next. epic difference and keeps weight down as well.. was gonna go JCW for brake bling and performance, if i went that route i'd probably get JCW pieces, but swap in Hawk HPS or HP+ pads for more spirited driving situations... stock pads for the Brembo JCWs seem to work great for street, and my lines would be transferable between the setups...
Old Nov 29, 2010 | 09:49 AM
  #30
ThePenl's Avatar
ThePenl
I have fitted to an S the JCW Brembo brake kit and I can say that generally speaking it is very good combination.
It is worth the money.
For my driving habits the factory JCW pads are too soft and replaced them to ferodo racing (they are much harder and they last longer as well while they don't seem to fade after hard use)
The disks are very nice and they dissipate heat quite well, though I think a disk with separate rotors and bells would do the job better.
If you want the ultimate combo no matter the cost go for an aftermarket four piston with rotors separate bells and pads by ferodo (maybe the ds3000)
Or if you would like to go one step further than the factory combo I would vote for the better disks and pads and fluids in the factory calipers.
It's up to you...
Old Nov 29, 2010 | 10:03 AM
  #31
czar's Avatar
czar
then you need the carbon ceramic rotor/pad combination, which is available for the mini, but will set you back $15K.
Old Nov 29, 2010 | 10:12 AM
  #32
ThePenl's Avatar
ThePenl
When I wrote no matter the cost I meant in real life...
Though I would love the carbon ceramic combination.
I have test drove one heavily modified car with that combo and I can say the braking force is sweet...
Old Nov 29, 2010 | 10:26 AM
  #33
czar's Avatar
czar
I too can vouch for the CC brake kit, I have it on my track intended project MCS Clubman.
Old Nov 29, 2010 | 01:31 PM
  #34
MotorMouth's Avatar
MotorMouth
ooOOoo I likey. Maybe we can get Dustin to start carrying them.
Old Sep 25, 2018 | 07:02 AM
  #35
MRH74's Avatar
MRH74
Simple answer, NO.
Not true
Konig dekagram 16x8 fit with r56 JCW brakes....personal experience
Aug 11, 2015 09:01 AM
nomar116
Aug 10, 2015 11:24 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
