Drivetrain Exhaust Header Install
Old Oct 11, 2010 | 09:04 AM
xman11's Avatar
xman11
I recently picked up a megan exhaust header but it didn't come with the mounting hardware. Does anyone know what size nuts/bolts I will need for connecting to the engine? Can the stock ones be used?
--e
Old Oct 11, 2010 | 02:41 PM
jhiggs26's Avatar
jhiggs26
Stock hardware is fine to use. Make sure the shoulders of the bolts sit flat against the header flange and not against part of a weld. If is does grind down the weld a bit. 18 ft-lbs.
You'll have to modify heat shielding a bit to clear the runners and O2 sensors.
Jeremy
Old Oct 12, 2010 | 01:36 PM
xman11's Avatar
xman11
Jeremy
Awesome. Thanks J!
squawSkiBum
Oct 2, 2015 09:21 AM
Aug 12, 2015 01:24 PM
sungjk
Aug 5, 2015 08:23 PM
