Drivetrain Quote from EVO November Issue
Old Dec 13, 2003 | 02:14 PM
resipsamcs's Avatar
resipsamcs
Forgive my ignorance, but I am not sure I understand the following quote from the November issue of EVO magazine: "The supercharger is a masterpiece of packaging, but the heat it generates is added to by the air blown through the intercooler above it. Not ideal." Is this simply a comment on the intercooler placement, and a situation without a true remedy?
Old Dec 13, 2003 | 02:32 PM
greatgro's Avatar
greatgro
Yes. Hot air rises. I don't think you can put it anywhere else and I believe the larger, aftermarket intercoolers are still on top.
Old Dec 14, 2003 | 12:47 PM
resipsamcs's Avatar
resipsamcs
Thanks greatgro, that is what I thought EVO was referring to. I am just not quite ready to swap out the intercooler for a larger air - air unit, or to a water - air unit.
Old Dec 15, 2003 | 01:26 PM
myminis2's Avatar
myminis2
if you look at all the WRX guys, they're big on making a front mount IC because of that very reason.
and for a MINI, man that is a tight fit
Old Dec 16, 2003 | 01:01 PM
kenchan's Avatar
kenchan
at least the intercooler is somewhat in front of the motor instead of
behind the motor like on my WRX. big difference in temperature.
these tmic's function just fine as long as there is moving air though.
_________________
03MCS IB/Blk: 123, Aerokit, R90 17x7, TK5 16x7, 6CDMP3, and a few more.
Old Dec 16, 2003 | 02:34 PM
cdconsor's Avatar
cdconsor
Waitaminuite, the advertising about the mini-madness intercooler says that this is exactly what we would want
"There simply isn't enough clean flowing space underneath the intercooler to provide proper airflow to remove heat and cool the intercooler. A good execution of this type of design is once again the Subaru WRX or STI where the intercooler is top mount but the difference it where it's placed, to the rear of the engine where there is plenty of space for incoming air to flow through the intercooler and escape through the empty space below."
So, is there a trade off here with regards to placement between airflow and heat?
healtoe86
Sep 15, 2020 07:25 PM
cawwwtun
May 3, 2016 08:03 AM
boostedhaze
Sep 2, 2015 07:56 PM
Sep 1, 2015 04:02 PM
