Drivetrain Tensioner rattle temporary fix
Old Jul 30, 2010 | 04:26 AM
  #26
Cadenza's Avatar
Cadenza
anyone with the tensioner out, can you get the part number of the damper?
I think it's made by Stabilus... maybe it can be tracked down.
thanks!
Old Jul 30, 2010 | 04:36 AM
  #27
CRoth's Avatar
CRoth
I have my old one at home. I'll check it out after work and post it here. Good idea btw.
Old Jul 30, 2010 | 07:50 AM
  #28
raven9mm's Avatar
raven9mm
Stabilus
Stab-o-shoc
D-56070
5754PR 112/02 D 02
The last time I was searching for replacement dampers, there was a thread that someone said that they went to Stabilus, and they refused to sell the part. Somehow it seems they have some kind of contract with BMW.
Still worth a shot, things might have changed.
http://www.stabilus.de/us/main/products/dampers.html
Old Jul 30, 2010 | 03:19 PM
  #29
Cadenza's Avatar
Cadenza
Originally Posted by raven9mm
Stabilus
Stab-o-shoc
D-56070
5754PR 112/02 D 02
Is that a BMW/Mini or Stabilus part #?
Sounds like an "exclusivity contract"... meaning BMW handed over a wad of cash to Stabilus to dictate how a component is distributed. In this case, it seems the damper can only be purchased as part of the complete tensioner assembly through Litens or Mini dealers.
Old Jul 30, 2010 | 05:00 PM
  #30
MINI33342's Avatar
MINI33342
Yep.....still hasn't changed since the last time I checked too.
Old Jul 31, 2010 | 03:20 PM
  #31
Cadenza's Avatar
Cadenza
Can't find anything for the Mini but there seems to be quite a few dampers for Mercedes C and E series available up to the late 90s. Price wise, they run $35-$55...
http://www.google.com/products?q=sta...ed=0CDkQrQQwAg
Unknowns:
1. Dimension & fitting - length of body and extension of the piston; diameter of the holes.
2. Damping rate: similar to Mini's?
Old Aug 4, 2010 | 12:35 PM
  #32
PA-MCS's Avatar
PA-MCS
I just discovered a piece of my powerflex belt damper bushing in my driveway I just installed them probably only less then 2 months ago. guess I'll be contacting powerflex. not sure where I bought them from..still going thru my emails.
Old Aug 5, 2010 | 06:09 PM
  #33
PA-MCS's Avatar
PA-MCS
Here are pics of my bushing. I just sent an email to powerflex. luckily I had my old dampener laying around
Old Aug 6, 2010 | 12:40 PM
  #34
Cadenza's Avatar
Cadenza
Can you measure the length of the the damper housing in mm? I'm trying to find out if it's possible to use Mercedes dampers. Thanks!
Old Aug 6, 2010 | 12:55 PM
  #35
00zero's Avatar
00zero
i was going to put these on this weekend but i think i will hold off.
At 50k i was going to replace as preventive but i guess ill just hold out on the stock.
Are there any batch numbers on the the powerflex brushings that might indicate what is bad?
-Jonathan
Old Aug 7, 2010 | 05:38 AM
  #36
CRoth's Avatar
CRoth
The body of the damper is 108mm.
Old Aug 11, 2010 | 07:38 PM
  #37
bodinski's Avatar
bodinski
Thanks for the replacement damper link Raven!
Old Aug 11, 2010 | 07:43 PM
  #38
MINI33342's Avatar
MINI33342
No link to an available product is there?
Old Aug 12, 2010 | 01:05 AM
  #39
Cadenza's Avatar
Cadenza
Forgot to ask... what's the diameter of the holes for the bolts.
Thanks!
Old Aug 13, 2010 | 08:12 PM
  #40
apexer's Avatar
apexer
I'll bet a dollar to a doughnut that the problem is the metal sleeve is too thick which doesn't allow enough material in the bushing to absorb the shock thus, it just hammers apart.
Old Aug 28, 2010 | 08:00 PM
  #41
apexer's Avatar
apexer
Any further info. on why the failures and if any corrective action has been suggested?
Old Sep 15, 2010 | 08:53 PM
  #42
jimz68's Avatar
jimz68
Powerflex UK told me they had a bad batch of the "goo" used to make the bushings. They sent me a replacement set made from the "new goo". Still don't know if I'll install them or not.
Jim
Old Sep 19, 2010 | 10:54 AM
  #43
apexer's Avatar
apexer
Jim
Thanks for the feedback. I hope you do install the new "GOO" ones and report how/if they stand up. Your the only one so far that I know that has the new goo stuff.
Old Aug 11, 2011 | 08:41 PM
  #44
MaxDraco's Avatar
MaxDraco
Looks like this site is suggesting a mercedes part to replace just the dampener:
http://www.all-miniparts.com/item.ww...s&weight=0.530
They also have a Meyle part listed on their mercedes website:
http://www.allmercedesparts.com/Shop...juster%20Shock
Old Aug 13, 2011 | 11:48 PM
  #45
luseboy's Avatar
luseboy
I knew these bushings wouldn't hold up! When I did my pulley, I had a tight budget and decided to not go for these. I have a huge amount of respect and trust for the powerflex bushings. I plan on replacing every single bushing on my car with them (with the exception of these and some others where i'd rather just replace the whole part with something aftermarket). I already have their engine bushings and have some trailing arm bushings coming in the mail soon. Their bushings are definitely super high qaulity, the tensioner just seems to be best fit to a rubber bushing. In this case, rubber wins over poly... imo anyways.
Old Jan 31, 2012 | 06:43 AM
  #46
tonywa28's Avatar
tonywa28
Powerflex failure - add me to the list
Tensioner bushing failed after a short period.....
Old Feb 22, 2012 | 07:38 AM
  #47
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
FWIW, I went by the M-B dealer today to compare some of their dampers. Much too big!
Old Mar 15, 2012 | 09:44 PM
  #48
MikeG37's Avatar
MikeG37
I tracked a rattle I was having down to the dampener last spring, the rubber bushing on the end toward the rear of the engine had completely disintegrated. I removed the dampener to get #'s off it to start my internet parts search... that's when I realized the little strut was shot, and probably hadn't been doing whatever it was designed to do for some time. When I then discovered getting just the dampener was next to impossible, and having driven the car a couple days without it didn't seem to cause any ill effects I just left it off and threw it in a drawer of my toolbox.
That was 11 months, and almost 13,000 miles ago
Can someone explain what purpose it serves anyway?
Old Mar 16, 2012 | 03:47 AM
  #49
CRoth's Avatar
CRoth
If your belt ever breaks, you're going to be in some trouble unless you've installed a tensioner stop or strap (same thing). The damper limits and smooths the range that the tensioner pulley can move. It's necessary and you're taking a risk driving without it.
I had my belt break a couple of months ago. No damage because my tensioner was completely in tact. Just a bit of a pain in the butt to change when you don't have any tools with you and I happened to be in BFE! Thanks to some friends driving me to a Harbor Freight for some basic tools, I was able to replace the belt and get back on the road. It would have been much worse if the damper was removed.
Old Mar 16, 2012 | 08:17 AM
  #50
CRoth's Avatar
CRoth
Maitland Imports in Orlando, FL has come up with a great solution for this problem. I don't want to speak for them so hopefully they'll post here. Just in case they don't, here is a number for them; (407) 425-0545. Ask for Ian.
