Drivetrain power mods
Old May 30, 2010 | 06:18 PM
aztec1382's Avatar
aztec1382
power mods
Time for the first power increase mod
What do you guys recommend
Dos intake or jcw stage 2 exhaust
And how is rmw tuning the cars can we just send them the ecu
Old May 30, 2010 | 07:21 PM
killerfox's Avatar
killerfox
get and intercooler and a tune. after that downpipe.
Old May 30, 2010 | 10:31 PM
Eds not-so-red MINI's Avatar
Eds not-so-red MINI
+1 on that.
Go here for info on the tune: http://www.revolutionmini.com/. Click on Products Page, then R56. If you're in CA or live near any upcoming local tuning events, you can just buy the tune; otherwise you'll need the flash tool, too. You download your stock tune into the tool, email the file to Jan, and he sends you back a modified file which you can upload back into your ECU. Turn-around is usually less than a day.
For intakes, word is that the best results are coming from a stock JCW air box.
Or do like I did ... I just got the tune on an otherwise bone stock R56 and got some rather impressive results.
Old May 31, 2010 | 05:59 AM
tvrgeek's Avatar
tvrgeek
Step ONE: What are you trying to achieve? Do you track it? Road or strip? Do you want off the line torque, corner exit, or peak? What will you be willing to give up? ( driveablity, peakeness, millage, durrablity, noise, tons of money)
Do you have an LDS? You just can't use much more power with one-wheel drive anyway.
Well, one could start with the works package. Intake, cat-back and tune. A known quantity at a known price. (high). From the charts, this provides power at the top end with not much help down low.
Be prepared to tune it several times as you go through different mods to suit your use unless you want to exactly copy another's all ready worked out configuration.
Old May 31, 2010 | 07:22 AM
slinger688's Avatar
slinger688
Factory mechanical LSD is OK at best. I guess it is better than if you don't have one.
Most aftermarket tuners tend to unlock high rpm power and torque as well.
Old May 31, 2010 | 12:13 PM
scottmd's Avatar
scottmd
This is my experience thus far as well!
Old May 31, 2010 | 02:57 PM
czar's Avatar
czar
If your looking for BIG HP, you will definitely need a mechanical LSD, Quaife etc etc.
To get yourself BIG HP, you should purchase yourself a JCW airbox, fit this with an ITG panel filter or similar, a high flow cat or catless downpipe, an uprated intercooler, fit a resonator delete hose, then get yourself the JCW exhaust manifold, and either purchase the JCW turbo or a hybrid KO3/KO4 do NOT purchase a GT2871RS as these are way too BIG, if you still want more power, then get yourself a ported cylinder head fitted with camshafts to suit, then after you amass all these lovely goodies, then go about getting a tune for them, this little lot will see you push the 300bhp mark.
larryd96
11
Sep 8, 2015 05:01 AM
tylewis
Sep 6, 2015 01:07 PM
ou812_tugger
Sep 5, 2015 03:24 PM
Ntety
Sep 2, 2015 08:39 PM
