Drivetrain Dinan CAI question
Old May 18, 2010 | 09:05 PM
tlr1000's Avatar
tlr1000
Dinan CAI question
Just installed my Dinan CAI.
I tried to use the supplied template to cut the req'd opening as best as I could. After finishing, I noticed there is a slight gap (bottom part of airbox near rubber moulding - right side of picture) that appears to be due to cutting too much out. Any idea if this gap is detrimental to performance? Wouldn't seem to difficult to seal it up.
I looked at a couple of install pics from other forum members and this seems like a consistent issue which leads me to believe its an inaccurate template.
Old May 19, 2010 | 12:23 PM
iceckid's Avatar
iceckid
Its made that way to suck in cold air through the cowl.
Old May 19, 2010 | 04:27 PM
ZippyNH's Avatar
ZippyNH
It may not look perfect, but I'm sure it will work fine. I have one and it is very hard to cut it perfectly....mine id pretty good, but I still have a small gap too!! I think part of the issue is that the template is 2D and you place it on a 3D item...
Old May 19, 2010 | 09:48 PM
tlr1000's Avatar
tlr1000
Thanks ZippyNH. I'd like to think it's a problem with an imperfect template rather than a lack of skill on my part
Old May 20, 2010 | 05:55 AM
gbx's Avatar
gbx
I used the Template.. and my cut out was too small so in the end it turned into test fittling and cutting more out so everything seated perfectly
Old May 20, 2010 | 06:58 PM
tlr1000's Avatar
tlr1000
The gap on mine isn't huge but annoying to a picky guy like me. Here's a close-up (see arrows):
patsum
26
May 29, 2021 06:29 PM
donniedarko
Oct 21, 2015 01:15 PM
rob76turbo
Sep 15, 2015 10:11 AM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
