Drivetrain Engine bushings?
Old May 12, 2010 | 07:19 PM
Headlands's Avatar
Headlands
Engine bushings?
It was recommended that I get these to reduce engine movement /knock that I now have because of the front control arm bushings making things stiffer and not sharing some of the play.
What are all of the benefits to replacement engine bushings? Is there increased vibration? Do they/can they make them in different "softness" levels?
Old May 12, 2010 | 07:54 PM
Porthos's Avatar
Porthos
I have the NM engineering insert and it just feel so much better. You lose power from the motor torquing so why not reduce that
Old May 12, 2010 | 10:00 PM
Headlands's Avatar
Headlands
Do you feel that there's noticeably more vibration with the NM inserts?
Old May 13, 2010 | 12:39 AM
ndylam's Avatar
ndylam
I have it on my car and I do notice a different when changing gears. Less rocking back and forth. It's a great gain for the amount of cash you're going to dish out.
Old May 13, 2010 | 05:04 AM
Porthos's Avatar
Porthos
There is a little more vibration but not a lot it really isn't that noticable but I have had inserts on other cars so I knew what to look for. You might not even notice it. Plus its not like your teeth are going to rattle out of your head.
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
Aug 21, 2015 10:07 AM
minipopkart
Aug 13, 2015 05:22 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
