Drivetrain Oil in thorttle body intake side...
Old May 6, 2010 | 09:24 AM
Hankfrum's Avatar
Hankfrum
So I installed the alta cai and noticed a little oily residue in the thortle body. I'm a little worried. Is this normale or is my MINI hurting? Its got 27k on it.
Old May 6, 2010 | 09:31 AM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
If it is on the inlet side of the T-Body (not opening the throttle plate and sticking your finger inside) it is probably jus over oiled filter syndrome. Which is easily corrected, wrap the filter in a paper towel and lightly squeese the oil out. Your car is fine.
Old May 6, 2010 | 09:58 AM
Hankfrum's Avatar
Hankfrum
I noticed it during the install...it had the factory box on it prior.
Old May 6, 2010 | 12:07 PM
DICKS GARAGE R53
The R53 MINI's seem to get quite a bit more oil vapor coming through the crank case breather than other cars. It might just be that, I would bet that if you pulled your intercooler off there would be quite a bit of oil left in there from the vapor. You could wash it out with a can or two of brake cleaner, and lightly wash off your throttle body at the same time.
Chances are you are ok.
Old May 6, 2010 | 12:29 PM
newbs49's Avatar
newbs49
Normal unless it's soaked. Clean the TB off as stated above. I usually do it once a year before track season, plus the intercooler at the same time.
Old May 6, 2010 | 02:39 PM
Hankfrum's Avatar
Hankfrum
Awesome!...yea its not soaked just had the residue...thanx guys
sevin
May 2, 2026 06:11 AM
Indimanic
Aug 19, 2015 11:08 AM
Emnotek
Aug 13, 2015 05:47 PM
Aug 11, 2015 09:01 AM
