Drivetrain R56 Cam options?
Old Apr 21, 2010 | 11:05 PM
justintime's Avatar
justintime
has anyone done r56 cams yet?
Old Apr 28, 2010 | 09:26 AM
btwdriver's Avatar
btwdriver
I would love an answer to this as well. I believe that Schrick has one in their catalog, not sure if anyone has installed it yet and if there are any issues tuning a car with one.
Old Apr 28, 2010 | 02:39 PM
czar's Avatar
czar
Scrick have two options of camshafts for the R56 N14B16 engine, stage 1 and stage 2, the latter (stage 2) does require the valve to piston clearance checking, and may require extra material removed from the piston valve relief area's, from having 10.7mm of lift. I know of 1 R56 running the Schrick stage 1, also having been a passenger in this car, I can comment that there was a distinct difference in power delivery in the mid to high end RPM, over stock, I think he has a dyno sheet too, if he has I will see if I or he can post up the results, if memory serves me correctly I seem to recal a figure of 271bhp.
Old Apr 28, 2010 | 04:39 PM
slinger688's Avatar
slinger688
Justin,
I was e-mailed some info on heads and cams for the R56 by Dustin at autoxcooper.com a few months ago. I think it was from Thumper Performance. You can checkout this link:
http://autoxcooper.com/thumper_heads.html
Old Apr 28, 2010 | 04:43 PM
btwdriver's Avatar
btwdriver
All of that info is referring to cams for an R53. I would imagine that anyone skilled at porting heads for the R53 can do so for the R56. But that info is specifically referring to R53's.
Teh
Aug 22, 2022 04:37 AM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
Accessory Products
Aug 11, 2015 12:19 PM
Aug 11, 2015 12:18 PM
