Drivetrain Oil Catch Can - Worth it?
Old Apr 19, 2010 | 08:16 AM
Sullosar's Avatar
Sullosar
Howdy Folks
So, while checking out some aftermarket mods I've been seeing these Oil Catch Cans around. I know what their sales pitch says, but can anyone tell me if they are actually worth it? What kind of impact do they have for performance / longevity?
I've got an R53 with 97K miles on it, so I'm interested in either of those two things, I'd just like to know some more about it.
Also, how often do you end up having to drain this can? Is it something I would be checking when I stop for gas? And do you throw the oil caught here away, or pour it back into the engine?
Old Apr 19, 2010 | 08:46 AM
ZippyNH's Avatar
ZippyNH
I think the general concenous is they don't do much on a r53.....they catch mostly water vapor....and just require emptying so you don't blow a motor...and the hoses can leak....there are def better places to spend a few bucks.....if you catch oil....consider it "spent" it has been cooked, vaporized, and re-condensed.....it is not fit for re-use.
Now if you said r56.......that is likely going to be a different story since they have huge intake/carbon issues due to being directly injected....
Old Apr 19, 2010 | 10:42 AM
Sullosar's Avatar
Sullosar
Beautiful, that's exactly the kind of information I was looking for. Thanks.
Old Apr 19, 2010 | 05:33 PM
herbie hind's Avatar
herbie hind
i like the cc . i have some blow bye so it works for me . it keeps the ic very clean . thus more efficient .
Old Apr 20, 2010 | 02:24 PM
DMBFan2's Avatar
DMBFan2
"I think the general concenous is they don't do much on a r53.....they catch mostly water vapor....and just require emptying so you don't blow a motor...and the hoses can leak....there are def better places to spend a few bucks...."
So is it worthless for the R53 then? I drive over 180 miles to/from work everyday and thought it might be worthwhile....not anymore...still confused on this.
What would be a better investment for an R53 that goes this distance everyday?
Old Apr 20, 2010 | 05:06 PM
ZippyNH's Avatar
ZippyNH
The idea of a catch can is it keeps oil from condensing in thr intercooler...Dr O, I think in tests showed the differance was neglible...1%...within the margin of error in the tests they did..he has published quite a bit...his site fesauto I think, under free stuff is where he archives much of it...very good reading, on many things. If you chat with a good mini performance guy, the catch can is considered underhood bling.
What to get depends on your goal...
If you want better mpg...an intake+ catback is good...becareful...some make a lot of noise.
Power...get a pulley.... Then an intake, and catback....
Want to make your carvmore relilable, do more frequent oil changes...7500 is a commn #.
If you want underhood bling....many things are functinal...if roads are bumpy, or you have 17 or 18' tires, get STD's to prevent strut tower mushrooming....
Comes down your goals!!
Mini Koopa
R55 :: Clubman Talk (2008+)
Sep 8, 2015 02:58 PM
kellymac
Aug 30, 2015 10:11 PM
Aug 21, 2015 12:59 PM
minipopkart
Aug 13, 2015 05:22 AM
M7Speed
Aug 6, 2015 01:48 PM
