Drivetrain HELP! Dieseling Problem
Old Apr 12, 2010 | 11:46 AM
PoktRokt's Avatar
PoktRokt
For the last week when I go to start the car up in the morning it instantly starts dieseling (not sure if that's exactly the correct word for it) to the point I have to turn off the engine and retry it several times while trying to give it gas. It usually takes two or three attempts to get it going. It seems like it is flooded/choking on too much gas. Does this sound like anything familiar to anyone? Could it be bad gas?
Old Apr 12, 2010 | 12:14 PM
iwashmycar's Avatar
iwashmycar
So it wont start??
Bad fuel pump. Search on here about it. Quite common
Old Apr 12, 2010 | 12:36 PM
dj.papazian's Avatar
dj.papazian
had the same problem. its most likely a bad fuel pump as mentioned above. hopefully your under warranty and your dealership will take care of it for you free of charge
Old Apr 12, 2010 | 02:26 PM
PoktRokt's Avatar
PoktRokt
Originally Posted by iwashmycar
So it wont start??
It eventually starts, but after a couple trys and some frantic accelerator action. Still think its the fuel pump?
Old Apr 12, 2010 | 02:27 PM
PoktRokt's Avatar
PoktRokt
So it wont start??
Old Apr 12, 2010 | 02:37 PM
dj.papazian
yep, still think its the fuel pump. my car wouldnt start until 2 or 3 tries. after i finally got it up and running i drove it right away to the dealership.
Old Apr 12, 2010 | 03:03 PM
iwashmycar's Avatar
iwashmycar
yup
Old Apr 12, 2010 | 04:39 PM
PoktRokt's Avatar
PoktRokt
Do you know if it was a fuel pump in the tank and/or engine? How long did it take to get replaced? I ask because I have to drive 200 miles to a dealership.
Old Apr 12, 2010 | 07:48 PM
dj.papazian
not sure if i understand your first question. my fuel pump was bad and had a leak...it took the dealership a few hours to take care of it (depending if they have a fuel pump in stock at the dealership)...if not they'll have to order it. if they are moderately busy that day, should take only a few hours.
Old Apr 12, 2010 | 09:29 PM
PoktRokt's Avatar
PoktRokt
My first question has to do with me hearing that there are two separate fuel pumps: One in the engine and one in the fuel tank. I was hoping it was the fuel tank so it would be potentially easier to fix. that may not be the case though
Old Apr 12, 2010 | 09:32 PM
ThumperMCS's Avatar
ThumperMCS
I would think the one on the motor (the HPFP) would be easier to replace. However, if you're out of warranty....get ready to pay $$$$...they are not cheap to replace.
Old Apr 12, 2010 | 09:59 PM
PoktRokt's Avatar
PoktRokt
I am still under warranty Do you think this is the issue as well? (I've also read about carbonization) I did seafoam it a couple times in the last few months. It seems to happen only in the morning (cold I guess).
Old Apr 12, 2010 | 10:08 PM
ThumperMCS's Avatar
ThumperMCS
Good! The HPFP's are like $1k!
It could be...
By 'dieseling' I assume you mean the motor is like turning over/barely running by itself, with no spark or fuel? My car did that during Seafoam treatments...it's kinda creepy.
Generally though with fuel pump issues, the car has trouble starting when cold (although mine never did...). One day mine just went into limp mode, and the internal code it threw was related to the HPFP. It was only putting out about half the PSI it should have been. I was also having big problems with pinging during this time, which went away completely after the pump was replaced.
However, I also did my first Seafoam treatments just prior, so its hard to say if it was the carbon buildup or the lack of output from the fuel pump which was causing it.
Old Apr 15, 2010 | 07:06 PM
miniinhd's Avatar
miniinhd
seafoam treatment
??????? WHAT is SEAFOAM TREATMENT???
Old Apr 15, 2010 | 08:24 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
Seafoam
https://www.northamericanmotoring.co...t-r55-r56.html
I did it, seems to help.
Old Apr 20, 2010 | 11:30 PM
PoktRokt's Avatar
PoktRokt
FYI - I just got my car back from the dealer and they said the car barely starting/dieseling on cold mornings is not from my fuel filter going out (it checked out okay), but from the free flowing aftermarket cat causing the O2 sensors to read irregularly - causing the issue. Not sure if this is the problem or not, but everything else on the car checked out okay.
Old Apr 21, 2010 | 05:52 AM
phlash's Avatar
phlash
for the sake of mentioning it.....have you checked that all four connections to it are tight (both sensors, the top and the bottom of the pipe) with no leaks? My idle is glass smooth.......I do BG 44k and seafoam every 5k...just did my third treatment.....
Old Apr 22, 2010 | 08:31 PM
PoktRokt's Avatar
PoktRokt
I haven't checked them but will this weekend. It's not that my idle isn't smooth though. It idles just fine once it gets going. And, my issue only happens on the coldest mornings for some reason. It seems like the car is choking and starving for gas. I push the accelerator to give it more gas and it then usually fires up as normal and runs normal from then on. This is why the bad fuel pump made sense. BTW - what is BG 44K??
Old Apr 23, 2010 | 06:46 AM
phlash's Avatar
phlash
Liquid gold.....
http://www.bgprod.com/products/fuelair.html
Stuff worked miracles for resurrecting some of my old Mazda rotories (they just crap carbon all over everything). Really good pro stuff. Not cheap, but really good stuff. Best pricing is usually on ebay motors.
Old Apr 23, 2010 | 06:50 AM
Porthos's Avatar
Porthos
Well sounds like someone needs a Walbaro 255lph fuel pump. Ya!!
UncDeo
Nov 4, 2019 04:08 AM
tylewis
Sep 6, 2015 01:07 PM
mikeandtricie
Sep 4, 2015 01:42 PM
mimaal
Sep 4, 2015 09:09 AM
Sep 2, 2015 09:05 AM
