Drivetrain '04 Upper Engine Support "Bad" - Replace whole bracket?
Old Mar 2, 2010 | 03:48 PM
Neufusion's Avatar
Neufusion
I have a 10/03 2004 MINI Cooper S. A mechanic said "the upper engine support is bad". I checked it out (#8 on the chart) and the rubber is failing. My question is if I am going use the PowerFlex bushings, is it wise to replace the whole part before adding the bushings or will the inserts handle well enough?
Old Mar 2, 2010 | 04:14 PM
ofioliti's Avatar
ofioliti
How did you tell that the rubber was failing? Lots of cracks? Thanks.
Old Mar 3, 2010 | 05:27 AM
Dave.O's Avatar
Dave.O
It is most likely failing because it is dry rotted, Split or very badly cracked for a 2004. After all it is 6 years old.
I would just replace it with another stock one. With the new PowerFlex bushing you are going to install it will not wear as fast because you will not have the same amount of flex as your car was when it was stock.
My $.02
Old Mar 3, 2010 | 07:41 AM
Bigshot's Avatar
Bigshot
I would just put the new inserts in. Mine looked a bit cracked up, but I see no problems now.
Old Mar 3, 2010 | 08:02 AM
Helix13mini's Avatar
Helix13mini
As a general rule, it's not good practice to band aid broken stock parts with performance parts. I always recommend fixing what's broken before adding the tuner parts to the mix. For example if you have a bad injector, don't solve the problem with a tune, solve it with a new injector. The same holds true for your motor mount. Fix it first, and then see if you need the stiffer bushing.
BTW, I like the old motor mount setup, with the dog bone, better than the new style cannister: not only does it last longer, I think there's less motor twist under load.
newbs49's Avatar
newbs49
Get the new OEM and add the insert to the new part.
Just my $0.02
Old Mar 3, 2010 | 08:06 AM
MINIdave's Avatar
MINIdave
I agree, fix the stock mount first. This is a very DIY friendly job if you have any wrenching ability at all...
As to the powerflex bushings, I put those in my '03 MCS JCW and hated it - the NVH was terrible, and it didn't do a thing to change what I put them in for. I was oh so happy the day I took them back out.....
Old Mar 3, 2010 | 08:15 AM
Bigshot's Avatar
Bigshot
If you don't do the lower engine mount (torque mount) the NVH can get bad. The lower one does more to stop the engine movement and adding the upper ones just evens it out. Have the upper and lower inserts for 4 yrs with no real NVH except at idle.
Old Mar 3, 2010 | 09:56 AM
Neufusion's Avatar
Neufusion
There are cracks between the larger ribs in the bushing.
Pics (sorry, taken at night trying to hold the flashlight and camera):
Old Mar 3, 2010 | 10:03 AM
ofioliti's Avatar
ofioliti
^ No need to apologize---excellent pictures! Thanks.
Neufusion's Avatar
Neufusion
I'm going to try out the BSH R53 Lower Engine Mount
Old Mar 3, 2010 | 01:06 PM
newbs49's Avatar
newbs49
Are you getting the street or race version? BSH.
The upper mount looks bad, that's a large crack.
Old Mar 4, 2010 | 04:59 AM
Helix13mini
Do it!
Old Mar 4, 2010 | 07:14 AM
Bigshot's Avatar
Bigshot
Another great option is this http://www.outmotoring.com/mini-coop..._bushings.html kit from Powerflex.
It replaces the bushings in the small ends of the dogbones and you get the inserts for the large end.
Old Mar 4, 2010 | 02:59 PM
Bajanmini's Avatar
Bajanmini
I have a full set of poly bushings in my car and removed the ones in the upper engine mount #8,it created too much vibration at idle and especially with the a/c on,otherwise it's all good.
Old Mar 4, 2010 | 06:59 PM
howsoonisnow1985's Avatar
howsoonisnow1985
Let us know how you like it. Considering it as well.
Cereall
Sep 5, 2019 06:05 PM
silence2-38554
Nov 12, 2015 09:39 AM
Zettinger
Aug 25, 2015 04:04 PM
