Drivetrain Belt size w/ 15% pulley
Old Feb 20, 2010 | 12:24 PM
mcsNathan's Avatar
mcsNathan
Hey everyone,
I'm preparring to have a 15% pulley installed on my S, does anyone know if the JCW belt P/N 11-28-7-545-120 6PK x 1374 will fit or should I use the aftermarket belts recommended to go with the smaller pullies? Thanks for the help!
Old Apr 18, 2010 | 08:44 PM
Sigop329's Avatar
Sigop329
I bought the one that Alta recommand with the 15% pulley (NAPA 060539)
and got a squealing noise. I've been told by a friend to buy the JCW belt.
Old Apr 18, 2010 | 09:47 PM
ZippyNH's Avatar
ZippyNH
Belt squeal comes from a miss-aligned pulleys, or contaminated belts (by oil or grease)......not a belt that is too long or too short (if it is slipping, it can make a bit of squeal, but most folks see power loss) I guess, but....the Goodyear Gatorback sometimes helps people with a mild squeal....unlike a traditional 6 rib, it has 6 ribs that start and stop....some have had problems....but if it fixes yours... There has been a bit of debate on the Alta recommended belts.....ask what people use, and the answers vary a bit.The problem with belts is the they vary in size, brand new....some 539's are some time shorter that 535's....makes no sense, but true...some love NAPA, some gates, some CarQuest...all made by Gates...but they vary...go figure. Also complicating the issue, is that the euro belt sizing system is different than the US system...
One tip....non-oem belts need to be change more often than OEM....and pulleys are tough on belts since there is less surface area for them to grip...so the smaller the pulley, the shorter the life of the belt...The SC consumes a huge amount of HP...so the belt does a lot of work too...many folks keep a spare belt in their cars just to be safe, and save a tow!!
Old Apr 19, 2010 | 06:04 AM
BlimeyCabrio's Avatar
BlimeyCabrio
I'm a big fan of the Napa 060535 belt on a 15% pullied car. And changing it yearly. Cheap insurance.
Old Apr 19, 2010 | 06:14 AM
Agarwaen's Avatar
Agarwaen
Also, tensioner stop. Cheap insurance that saves you a lot of headaches if the belt come completely off or snaps.
Old Apr 19, 2010 | 06:40 AM
mini_racer's Avatar
mini_racer
YES
and YES
Old Apr 19, 2010 | 03:17 PM
broadwayline's Avatar
broadwayline
Thirded, I run the same combo.
The Alta sheet is wrong, old outdated information.
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
The_Kid
Nov 3, 2016 06:30 PM
larryd96
11
Sep 8, 2015 05:01 AM
M7Speed
Sep 3, 2015 07:48 AM
