Drivetrain Meatloaf and gravy
Old Feb 6, 2010 | 09:59 AM
  #76
Dr Obnxs's Avatar
Dr Obnxs
It's brain-dead easy..
remove old cover.
remove IC boots
Remove front IC support brackets.
Remove IC.
Remove rear IC supports
Install new IC rear support.
Install IC& Boots
Install front supports
Install cover
DONE! If you're good with yanking the IC. It's less than 1/2 hour.
Also, since the GP covers the plug access a bit, take the time to make sure your plugs are torqued.
Also, the rear passenger side support can wear thicker, less flexy aftermarket plug wires. Make sure they aren't rubbing too much.
Matt
Old Feb 9, 2010 | 06:53 PM
  #77
dhabutcher's Avatar
dhabutcher
Any photos?
Old Feb 10, 2010 | 10:14 AM
  #78
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Thanks Doc !
Old Feb 10, 2010 | 11:04 AM
  #79
herbie hind's Avatar
herbie hind
Originally Posted by WolfGTI
You also need to figure where you will have the heat exchanger that cools the fluid going to the reservoir. It will need very good airflow to bring down the water temps - water retains its heat longer than air - so once the total fluid mass is hot it will need very effective cooling to bring it back down so that it makes a difference in cooling the intake charge.
mount a radiator from an automatic and instead of tranny cooler it's now a i.c. cooler!!!
Old Feb 11, 2010 | 08:23 PM
  #80
herbie hind
my bad . the auto's used external cooler . still though it looks like a good spot and made to fit .
Old Feb 11, 2010 | 09:19 PM
  #81
JIMINNI's Avatar
JIMINNI
My GP IC is inroute
Old Feb 12, 2010 | 07:24 AM
  #82
lhoboy's Avatar
lhoboy
Originally Posted by Dr Obnxs
remove old cover.
remove IC boots
Remove IC.
Install IC& Boots
Install cover
Matt
You also need to r&r the bonnet mounted baffle (diverter) with the one specific to the GP IC.
Old Feb 12, 2010 | 07:53 AM
  #83
Dr Obnxs's Avatar
Dr Obnxs
Turns out...
that's pretty much the same part.
Matt
Old Feb 12, 2010 | 08:37 AM
  #84
lhoboy's Avatar
lhoboy
Matt
I'll try to get side by side photos. The diverter for the GP IC extends the scoop back further (just a bit) to expose the back two fins that would otherwise be blocked by the standard diverter. It also fits properly around the new cover. It looks to me like the standard diverter would require some trimming or cutting to fit down on the larger IC cover.
Old Feb 15, 2010 | 03:55 PM
  #85
MINICHEF's Avatar
MINICHEF
Originally Posted by JIMINNI
My GP IC is inroute
Do tell Jim, Do tell pics please
Old Feb 16, 2010 | 10:04 AM
  #86
//MZero's Avatar
//MZero
Has anybody looked into taking two stock IC's, cutting off the end tanks, welding the cores together to make a thicker IC then making new end tanks.
This should keep thermal efficiency low, but improve cross sectional area. This is of course if it could fit.
Old Feb 16, 2010 | 10:31 AM
  #87
SlowGSX98's Avatar
SlowGSX98
I'm pretty sure that Helix made something similar to this, and it didnt work to good
Old Feb 16, 2010 | 10:58 AM
  #88
Helix13mini's Avatar
Helix13mini
Interesting idea, but the problem is fitting it in the top mount area and getting good flow across it.
Old Feb 16, 2010 | 11:01 AM
  #89
JIMINNI's Avatar
JIMINNI
It's ordered and payed for, now just have to sit and wait Ordered it through a dealer, no questions asked
Charge-air cooler 17517565302
Sealing plate, charge-air cooler 17517565345
Old Feb 16, 2010 | 11:05 AM
  #90
newbs49's Avatar
newbs49
Did you order the different brkts needed?
Old Feb 16, 2010 | 11:12 AM
  #91
Revolution Mini Works's Avatar
you know partsman can get fired for that.... right?
Old Feb 16, 2010 | 11:15 AM
  #92
JIMINNI's Avatar
JIMINNI
Hmm....since I haven't talked to Partsman about it....what are you talking about?
Old Feb 16, 2010 | 11:18 AM
  #93
JIMINNI's Avatar
JIMINNI
The front brackets are the same, i'll see if the rears are needed. If needed, most likely just make some.
Old Feb 16, 2010 | 12:00 PM
  #94
Partsman's Avatar
Partsman
Legion_of_Doom
Not really...but I appreciate your concern.
To be honest, I didn't order that one for Jim...but his experience sounds exactly like what I have heard concerning GP parts. They are just shipping the stuff no questions asked.
Old Feb 16, 2010 | 12:36 PM
  #95
D-MAN's Avatar
D-MAN
You don't need the rear brackets - I ran one for several months without them
Old Feb 16, 2010 | 12:48 PM
  #96
JIMINNI's Avatar
JIMINNI
Thanks D-MAN
Old Feb 16, 2010 | 01:21 PM
  #97
newbs49's Avatar
newbs49
no rear brkt = cut plug wires at times.
Old Feb 17, 2010 | 03:07 PM
  #98
-=gRaY rAvEn=-
Moderator
MINI has a ton a GP parts in storage, especially crash parts. They need to make room and move some of thier stock.
What they didn't plan for back in 06', was for the many GP owners to either never put very much mileage on their cars, or to see them mothballed in a garages. And never figured on having this many parts in still in stock. I get a sense you will see more of these parts being freed up and bolted to many 1st Gen MINI's.
Old Feb 17, 2010 | 03:38 PM
  #99
JIMINNI's Avatar
JIMINNI
If only the GP wing wasn't so expensive.....
Old Feb 18, 2010 | 03:35 AM
  #100
lhoboy's Avatar
lhoboy
The front brackets will eventually fatigue fail if the back of the IC is not properly secured with brackets.
