Drivetrain Aftermarket Crank?
Old Dec 4, 2009 | 07:52 PM
coopselt's Avatar
coopselt
From: Camano Island, WA, but wish was still Oahu, Hawaii
Aftermarket Crank?
And also since pulling the motor, they say I will have to do some machine work on the crank. I'd rather put money into an aftermarket one vice money into repairing the stock one. But seems that this is a very limited market.
Anyone out there have experience with aftermarket cranks for our MINI S's?? Or, know what I can do with the stock one to improve on it while out?
THANKS
Old Dec 4, 2009 | 08:02 PM
Dr Obnxs's Avatar
Dr Obnxs
The stock crank has a nitride coating I think..
so I don't know how easy it is to work on. Jan at RMW has an aftermarket crank, but it may be for a stroker... Give him a call!
Matt
Old Dec 6, 2009 | 01:42 PM
coopselt's Avatar
coopselt
So this means not even lightening the crank then? Anyone here even shaved off some metal to save on rotating mass weight?
Old Dec 6, 2009 | 04:30 PM
R53-BRG's Avatar
R53-BRG
Old trick to make an engine rev faster. Most "worked" stock cranks on built motors will have a "Knife Edged" crank. You only shave off about as much rotational mass as adding an lightened crank pulley. But for a motor that is built primarily to squeeze every last bit of oomph out of the engine, by all means knife edging the crank is a cheap option for a higher, faster revving engine.
Check with local machine shops, usually most of the old school machinists build race motors in their spare time and could shed more light on the subject for you.
Old Dec 6, 2009 | 06:50 PM
Dr Obnxs's Avatar
Dr Obnxs
Sure!
but working on the bearing surfaces is the tough part....
Matt
Old Dec 7, 2009 | 08:53 AM
2mD's Avatar
2mD
( not mine by the way )
elverado
Jan 18, 2022 02:51 AM
BernieCoop
Sep 10, 2021 03:15 AM
VanisleRyan
Sep 13, 2015 09:55 PM
boydie
Sep 13, 2015 05:06 PM
