Drivetrain Powerflex Upper Engine Support
Old Oct 5, 2009 | 09:59 AM
BLU-BY-U's Avatar
BLU-BY-U
I have looked around and can not find instructions on how to install the Uppers on a Nov 2003 MCS. Anyone?
Is it as simple as unbolting the mount and inserting the new poly's into the top and bottom? Should I use the supplied grease with it, or not? Also I have the small upper bushing, it looks straight forward too, but...
Old Oct 5, 2009 | 10:28 AM
CrazyIvan's Avatar
CrazyIvan
from your post sounds like you already know how to do it. It really is that easy.
Old Oct 5, 2009 | 10:40 AM
daflake's Avatar
daflake
Yes, use the grease.
Old Oct 5, 2009 | 11:17 AM
BLU-BY-U's Avatar
BLU-BY-U
Do I need to jack up the engine or anything, Or is it as easy as loosening the bolts and taking it off and inserting it, that is really my question.
Old Oct 5, 2009 | 11:39 AM
jimz68's Avatar
jimz68
No jacking required. Have at it and report back.
Jim
Old Oct 5, 2009 | 11:51 AM
BLU-BY-U's Avatar
BLU-BY-U
Ok, I will take pictures and post the results. I can't believe that I will be the first to do this. I mean it is a simple one, but...
Old Oct 5, 2009 | 12:07 PM
Mike S's Avatar
Mike S
Those plates are a PITA to get in with the old OEM bracket. Expect a lot more vibration, but the feel is more direct!
Old Oct 5, 2009 | 07:12 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You got it right, no jack needed. Just remove the braket insert the Powerflex bushings and reinstall the bracket. It's not hard, just don't overthink it.
Old Oct 5, 2009 | 08:20 PM
not-so-rednwhitecooper
Make sure it comes with two large washers. The bushing is useless without them. It will slowly work its way out and start to cut into the bushing.
I got a set from Outmotoring without the washers. (The only reason I know about them is I had a set on my old S in 2006 and it had washers) The difference between the bushings with and without the washers is night and day.
Old Oct 5, 2009 | 09:07 PM
BLU-BY-U's Avatar
BLU-BY-U
In the kit what I got was the small upper kit (two small purple poly bushings & one metal sleeve), the large upper kit (two large yellow poly bushings & two large metal washers) and a pack of copper silicone grease. Here is a picture:
Attached Thumbnails Powerflex Upper Engine Support-powerflex-largeandsmall-upperkit.jpg
Old Oct 5, 2009 | 11:10 PM
jollyroger927's Avatar
jollyroger927
Does anyone know if the lower engine mount powerflex bushings are supposed to come with washers? Mine didnt. Thanks
Old Oct 5, 2009 | 11:34 PM
No, I dont think they do.
Its just the way the upper one has force applied to it. its different for the lower.
Old Oct 5, 2009 | 11:39 PM
SlowGSX98's Avatar
SlowGSX98
Mine didn't come with washers for the lower either
Old Oct 6, 2009 | 06:49 AM
jollyroger927
Okay thanks for the info.
Old Oct 6, 2009 | 08:10 AM
BLU-BY-U's Avatar
BLU-BY-U
MINI-Madness wrote this install guilde for the lowers, but I can't tell from it if they have the washer, but looking at the install pictures it looks like part of the frame looks like it holds it in.
http://www.mini-madness.com/pdf_file...structions.pdf
Old Oct 9, 2009 | 01:28 PM
BLU-BY-U's Avatar
BLU-BY-U
Ok, I decided to do this on my lunch break today. I would say it would take less than 30 minutes to do if you aren't trying to get the perfect picture, me it took an hour.
Step 1.
Remove the bolt holding down the bracket arm holding the cables and vacuum lines to the brace
Step 2.
Roll up the bracket up and over as far as you can without forcing it too hard
Step 3.
Remove small bushing bolt (16mm)
Step 4.
Remove Large Bushing Bolt (16mm)
Step 5.
Fish the brace out pulling the small bushing part up and over to the left and than sliding it out
Step 6.
Remove the Rubber Nipple from the upper bushing, use plyers or a util knife
but only the raised Nipple see sample with and without
There should be nothing to remove on the bottom bushing (there is a raised rubber key that both of the yellow bushing will fit into on the bottom (interchangeable)
Step 7.
Lube up old small bushing and push out
Fish old bushing out from backside (easiest to push instead of pulling it out)
(Clean up and off lube used to removal old small bushing making it clean)
Apply new Copper grease to one of the new small bushings and slide into backside
Grease other small bushing and insert, then grease sleeve and insert
Step 8.
Grease large bushing
Smear grease around completely
Insert top and bottom Large bushing into the factory rubber bushings
Spread brace arm to allow for extra room for new bushings and washers
(this is the best thing to do otherwise you mess with it forever)
Reinstall brace the opposite from removal
Slide washers into place on the top and bottom
(a long flat head screw driver will help position the lower washer)
Insert long 16mm bolt back in and start monkeying with the lower washer to get the bolt started, once the bolt is start tighten down
The lower washer will be flush with the New large bushing
Step 10.
Insert short 16 mm bolt into small bushing and tighten down
Step 11.
Reattach the bracket to the brace and tighten down (make sure the slot down from the bolt is threaded onto the brace)
(see picture above)
That's it. Now go motor through some twisties and let the bushings work their way in and revisit to check bolts for factory torque, which I will put in if anyone knows.
I will update with anything anyone has a problem with.
Attached Thumbnails Powerflex Upper Engine Support-bracket-bolt6x4.jpg   Powerflex Upper Engine Support-bracketboltremoval6x4.jpg   Powerflex Upper Engine Support-rollingbracketup6x4.jpg
Old Oct 9, 2009 | 02:02 PM
Alan's Avatar
Alan
Thanks BLU, I'll be doing this at the end of the month.
Alan
Old Oct 10, 2009 | 07:58 AM
Mike S's Avatar
Mike S
I didn't use any of the lube :D Nice write up!
Old Oct 10, 2009 | 11:33 AM
BLU-BY-U's Avatar
BLU-BY-U
That is why you had more trouble getting the washers in then!
Old Oct 10, 2009 | 04:38 PM
Put the lowers in.
You really should do them at the same time. The motor still bucks pretty bad till the lower ones are in. The tranny mount help some as well.
Old Oct 10, 2009 | 04:56 PM
WayMotorWorks
Vendor
Nice write up. It's always good to show how easy the powerflex bushings install.
Toolman
Jan 20, 2016 06:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
Sep 17, 2015 09:27 AM
sleek55044
Aug 21, 2015 10:52 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
