Drivetrain short shift kit install help
Old Aug 15, 2009 | 04:01 PM
CaMiniMe's Avatar
CaMiniMe
i am installing the helix short shift kit and im running into some problems. this may seem lame but i cannot find the 2 15mm bolts the instructions talk about. can someone help me and tell me where the 15 mm nuts are?
thank you
Old Aug 16, 2009 | 10:54 AM
MINIutia's Avatar
MINIutia
Helix SSK
The instructions refer to a an earlier model. In an R56, remove the DownPipe to exhaust T-bolt clamp to drop the exhaust. You'll also need to slip the rubber exhaust mounts off the hangers rather than unbolt them.
thank you
Old Aug 18, 2009 | 09:53 AM
CaMiniMe's Avatar
CaMiniMe
ok that makes sense. no wonder i couldnt find the 2 bolts. so is there a trick to sliding out the hangers from the rubber pieces?
thanks
Old Aug 18, 2009 | 10:14 AM
MINIutia's Avatar
MINIutia
SSK Install
Apply a soap solution to the hangars, unbolt the T-bolt and disconnect the DP to exhaust before you manipulate them. The clamp/T-bolt often sticks after loosening the T-bolt, you may need to pry the clamp ends apart. Also, place a towel on top of the exhaust tips so that when you lower the exhaust there is some padding between the tips and the rear body panel when they touch. I recommend limiting how far you lower the exhaust to avoid damage to the plastic body panel. Provided you don't force the disconnected pipe downwards this should not be a problem.
thanks
Old Aug 18, 2009 | 10:50 AM
CaMiniMe's Avatar
CaMiniMe
great. thanks a lot for the input
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
squawSkiBum
Oct 2, 2015 09:21 AM
