Drivetrain Running too cold
Old Aug 11, 2009 | 02:49 PM
Northerner's Avatar
Northerner
Running too cold
Fitted a 82deg C thermostat and took the car out for a spin.
On the motorway, the coolant temp dropped to below 65deg C, on the country back roads the temp went up to the mid 70's deg C and sat idling on the drive and the temp only went up to 83ish.
Changing the thermostat, I presume wouldn't drop the temp by that much also I guess running the car at these temps isn't going to be good for it.
Before with the standard thermostat the temp stayed around the 93-100deg C mark.
Any ideas?
Old Aug 11, 2009 | 03:05 PM
herbie hind's Avatar
herbie hind
what's that in fahrenheit?
Old Aug 11, 2009 | 03:10 PM
Bigshot's Avatar
Bigshot
Yea, you are running way to cold. Constant temps should be around 100-105C
Old Aug 11, 2009 | 04:24 PM
kapps's Avatar
kapps
Yeah that's pretty cold. My Scangauge indicates coolant temps between 195 and 205F (90-96C) usually centering in the middle of the range. Running the engine cold means the ECU may try to keep you in warm-up mode which will use more fuel. It's also keeping the oil cooler which will result in more viscous friction.
Old Aug 11, 2009 | 04:39 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Did you get the system bled after draining some to get the new thermostat in? You could still have an air bubble.
Old Aug 11, 2009 | 05:19 PM
herbie hind
that would more likely cause a heat condition
Old Aug 11, 2009 | 05:53 PM
//MZero's Avatar
//MZero
Sounds like the thermostat is stuck open. Take it out and test it in a pot holding it with some tongs as you heat water up to a boil. If it works, then maybe you put it in wrong.
Old Aug 11, 2009 | 07:12 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Any ideas?
What's an 82DEG C Thermostat ?
Is that the same thing as an 180 o Thermostat ?
Old Aug 11, 2009 | 10:56 PM
//MZero's Avatar
//MZero
come on people...you guys really fail http://www.google.com/search?hl=en&c...enheit&spell=1
Old Aug 12, 2009 | 06:16 AM
herbie hind
thx mzero . so looks like it's stuck all right . but how long at freeway? it shoulda closed and the temp woulda come up, but not necessarily on a quick on off freeway . i'd let it idle and see if hoses both go hot . or even out in temp indicating coolant flow thru block . then if it is working; is it too cold? do you live in fl. tx.?
Old Aug 13, 2009 | 04:09 AM
Northerner's Avatar
Northerner
I've refitted the old standard (195deg F) thermostat and refilled the cooling system.
However, the low coolant temp issue is still evident as when i'm driving around @ 30mph the coolant temp is @ 180 deg F but on the motorway the temp drops to @ 153 deg F. The time spent on and off the motorway works out to @ 15mins each.
I've checked the thermostat housing for any cracks and the thermostat worked before it was taken off, leaving me at a loss as to why the temps are soooo low.
Any ideas?
Also, the outside temp was 68 deg F.
iggi
18
Feb 9, 2026 01:00 AM
TREX
Nov 2, 2019 07:31 PM
alistaircookie
Oct 8, 2015 10:52 AM
minicoclub
Aug 25, 2015 09:07 AM
Powershift
Aug 16, 2015 05:14 PM
