Drivetrain How do I get this engine bush out?
Old Aug 7, 2009 | 08:58 AM
Mike S's Avatar
Mike S
Been trying for the last 20 mins, no success. Anybody have any pointers on how to get this darn thing out? I am replacing it with the purple powerflex version
Everything has been unbolted already.
Thanks much in advance!
Old Aug 7, 2009 | 10:49 AM
herbie hind's Avatar
herbie hind
try removing it from vehicle (use jack and wood to hold engine up ). and press it out with vise and socket .
Old Aug 7, 2009 | 10:57 AM
Mike S's Avatar
Mike S
Thanks for the pointer. I'd prefer not to totally loosen the engine I'm even contemplating drilling it out
Old Aug 7, 2009 | 12:11 PM
not-so-rednwhitecooper
You need to press it out. Theres a simple tool you can make for this.
You need a threaded rod, two nuts, a piece of tubing and two washers.
The threaded rod and nuts should have the same thread, and should fit inside the hole on the bushing. The tube should be about 3 inches long, and the ID should be greater than that of the bushing. One washer should have a diameter that the same or larger than the piece of tubing, and the other washer should be the same size or slightly smaller than the bushing.
Assemble like so...
--0-)---[____]--||--(0-
Nut, washer, tube, (bushing) washer, nut, with the rod in the middle.
Tighten the nut on the right so you have a few threads engaged, then torque the left net down till the bushing pops.
Old Aug 7, 2009 | 12:50 PM
k-huevo's Avatar
k-huevo
Post #3&4 here http://www.lonestarminiclub.com/foru...read.php?t=526 for another way.
Old Aug 7, 2009 | 12:52 PM
Mike S's Avatar
Mike S
Thanks k! I eventually got it out. I got a stanley knife and cut away the edges of the rubber and then knocked it out with a hammer. Was rather quick and easy
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
Aug 21, 2015 10:07 AM
minipopkart
Aug 13, 2015 05:22 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
