Drivetrain R53 Exhaust, Head, Header Survey
Old Jul 30, 2009 | 09:08 PM
smportis's Avatar
smportis
R53 Exhaust, Head, Header Survey - Take it!
Hello fellow NAMmers,
It has been almost a year since I last did the exhaust survey for the '02-'06 R53 MINI Cooper S.
This year, I'm using a different survey system (thank you Google Docs) that is both free, and unlimited, so hopefully it won't cut off after 100 responses.
Also, I'm adding, by request, a survey for both Heads and Headers this year. I don't know them all, so I might have missed a couple. Just write them in the "Other" spot, and I'll compile all the data and post it in the R53 Exhaust Thread in a couple of weeks.
I *may* do a R56 survey as well, but will have to research the exhausts for that model a bit more. Should be fun.
Please let your friends know about this survey.
Click here for 3 Question Survey (literally takes 30 seconds)
*Post a reply here after you fill out the survey. Keep this posting from dropping out of view. I'll shut it down after a couple of weeks if it goes that long.*
Old Jul 30, 2009 | 09:58 PM
glnr13's Avatar
glnr13
posted. interested in seeing the results after a few hundred more post.
Old Jul 31, 2009 | 05:53 AM
smportis's Avatar
smportis
25 surveys thus far. Keep it going!
Old Jul 31, 2009 | 09:43 AM
DarrenO'sideCA's Avatar
DarrenO'sideCA
Survey completed.
Old Jul 31, 2009 | 10:40 AM
M3NTAL's Avatar
M3NTAL
Completed - do not have permission to access results.
Old Jul 31, 2009 | 02:11 PM
bratling's Avatar
bratling
Super Moderator
I think OP fixed that, because I was able to see them when I took they survey just now.
Old Jul 31, 2009 | 02:18 PM
miniblucabrio's Avatar
miniblucabrio
survey done
Old Jul 31, 2009 | 06:46 PM
smportis's Avatar
smportis
No, I did not change anything to fix it. Do you mean you cannot access it from the link here:
Survey Results
or do you mean you cannot see it immediately after you finished the survey in the little window that popped up that said "Thank you, you are done. Click here to see the Results."?
If it is the link, I'll see what I need to do to fix that - probably need to share it in google docs.
Thanks,
Scott
EDIT: Yes, I see now that you have to be logged in to click the link above. Can't get around that right now. Will publish results later.
Old Jul 31, 2009 | 09:52 PM
discodan's Avatar
discodan
completed
Old Aug 1, 2009 | 08:34 AM
CrazyIvan's Avatar
CrazyIvan
survey done
Old Aug 1, 2009 | 08:59 AM
firenewt's Avatar
firenewt
Survey done.
Old Aug 1, 2009 | 09:31 PM
smportis's Avatar
smportis
Yes, sorry about that. Google Forms is somewhat new, and has some limitations. I'll post results after we get 2 weeks of responses.
Old Aug 2, 2009 | 05:07 AM
Machupo's Avatar
Machupo
looking forward to the results!
Old Aug 24, 2009 | 09:20 PM
smportis's Avatar
smportis
Closing in on 100 responses. Sorry for the delay in bumping. Been out of town for a couple of weeks.
Old Aug 25, 2009 | 05:51 AM
WolfGTI's Avatar
WolfGTI
Filled out survey.
Old Aug 25, 2009 | 06:38 AM
Hippie's Avatar
Hippie
Done
Teh
Aug 22, 2022 04:37 AM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
MIminiclubman
Aug 5, 2015 09:14 PM
