Drivetrain Boost Controller
Old Jul 2, 2009 | 12:03 PM
08bluecoop's Avatar
08bluecoop
Boost Controller
I just purchased my friend a boost controler for his 08 cooper s.
He has no other mods and would like few more pounds of boost.
Can I sneek a few lbs past the ecu?
How many lbs of boost can i safely add without any other mods?
Any Pics of aftermarket boost controlers.Or install instructions.
I know a lot of people have this done in the tune but I wanted to get him something under $125
Dont hammer me too much...I trying to get him going with the mods. I figured a few more lbs of boost would give him the itch.
Old Jul 2, 2009 | 01:26 PM
Ottoman_FD3S's Avatar
Ottoman_FD3S
sorry bro, u wasted ur money
the MCS doesn't have a traditional Wastegate solenoid with a spring connected to a vacuume source..
the ECU directly operates a solenoid and fluctuates the boost patterns on the fly all the time.. Hence the overboost function... boost levels also change according to Live data from the ecu
such as Intake temps, Coolant temps, Knock sensor feedback, timing advance, etc etc
basically the ECU has Fuel Maps, Ignition Maps, and Boost curve maps
*Cliff notes* u can't bypass the ecu with it throwing a fit
Old Jul 2, 2009 | 09:28 PM
vmk82's Avatar
vmk82
i tried installing a boost controller on my car once and no matter if i had it set at stock levels or upped boost ,.,.,my car wouldnt make any boost at all.,., ecu shut down making boost when it was installed
Old Jul 13, 2009 | 07:16 PM
MotorMouth's Avatar
MotorMouth
You need to do a lot more reading before recommending any mods to your friend unless you want him to stop being a friend.
Old Sep 7, 2009 | 07:21 PM
tai842000's Avatar
tai842000
Need to trick the ECU, or make it less smart, so it wont get crazy with the extra boost.
Its a car after all.
Old Sep 7, 2009 | 07:24 PM
ThumperMCS's Avatar
ThumperMCS
Your posts make me laugh
Old Sep 8, 2009 | 03:35 AM
MotorMouth's Avatar
MotorMouth
not as much as the ones i expect to see in the future.
Old Sep 8, 2009 | 01:47 PM
tai842000's Avatar
tai842000
i hope my dyno has same effect for you guys...
http://www.youtube.com/watch?v=WXk62DAvk38
Old Sep 8, 2009 | 04:24 PM
MotorMouth's Avatar
MotorMouth
not bad numbers although a little lower than what most JCWs are reporting. That could be due to dyno differences too though.
edit: actually after seeing your mod list I'd be upset. You have a full turbo back exhaust?
Old Sep 8, 2009 | 04:30 PM
tai842000's Avatar
tai842000
This is WHP. I believe data from mini is flywheel horsepower. Maybe someone can confirm this?? I am shooting for 250- 260whp .
Old Sep 8, 2009 | 09:08 PM
ThumperMCS's Avatar
ThumperMCS
Yea...me too
...on the stock turbo? not happening....
If you're at 260 wheel...you're going to have almost 300 ft-lbs to the wheels, and I just don't see that happening with a stock turbo.
Although, maybe with your boost controller....
Old Sep 8, 2009 | 10:45 PM
SweetPeaBlue's Avatar
SweetPeaBlue
stock JCW puts down 190whp/192wtqe (BONE STOCK) on the ABF Mustang Dyno... so the numbers on his youtube is within range (kinda sorta)... just my 2 cents.
Old Sep 9, 2009 | 12:01 PM
tai842000's Avatar
tai842000
Yea...me too
Interesting... If I can control the boost let see how much power can stock turbo make on this car!!! This car will go back to the dyno again hopefully with more hp to the wheel.
Old Jul 25, 2013 | 04:33 AM
Hank Rearden's Avatar
Hank Rearden
I know this is a very very old thread. Dont know why some lough...just change the oue vaccum wastgate for a good standard pressure commanded one, install a ebc or mbc, do the chip to avoid errors and give more fuel to the engine and you will control all the boost the turbo can give whenever you want...
Old Jul 25, 2013 | 10:12 PM
Step's Avatar
Step
Old Jul 26, 2013 | 06:36 AM
Hank Rearden
Originally Posted by Step
Filmy
15
Jun 6, 2023 06:27 AM
molala
Oct 2, 2015 01:53 PM
Sep 11, 2015 11:09 AM
mbatech
Sep 10, 2015 03:40 PM
Filmy
Sep 7, 2015 11:27 AM
