Drivetrain chrono pack oil guage accuracy
Old Jun 24, 2009 | 12:23 AM
blue al's Avatar
blue al
has any one any idea of the accuracy of the chrono pack oil temp guage
my oil always seems a little high temp wise,
esp on track days 130ish degrees c is not unknown
do i need another guage? or will it tell me the same thing?
so should i spend the money reducing the temp rather than measuring it twice
Old Jun 24, 2009 | 12:38 AM
user 7082082's Avatar
user 7082082
That is accurate. It translate to 266 degrees Fahrenheit. I had seen this temp plenty of times during hot track days. I since purchased an RMW oil cooler, and along with a 180 degree thermostat, my oil temps are 190-220F and do not go higher. Driving on the street I see 170-190F. I also use 10-50w oil.
Old Jun 25, 2009 | 05:44 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
I've come to the conclusion that the Chrono Pack Oil Temp Gauge reading is a calculated value by the ecu. No one, I repeat, no one has been able to find a temp sensor for this gauge and not even MINI techs have the slightest idea what makes it work. Yes, the gauge responds. Yes, it probably gives a representative idea of oil temp but, as for real sump temp of the oil, I seriously doubt its accuracy. I welcome info. to the contrary.
Old May 3, 2011 | 02:48 PM
blue al's Avatar
blue al
old topic comes back
recently stuck an m7 thermostat into my 20% m45 mini
and now my "chrono oil temp" is much lower
so the ecu is not calculating from rpm
i think its now taking a best guess based on water temps....
Old May 3, 2011 | 03:54 PM
rwkeating's Avatar
rwkeating
I am guessing they are using RPM, water temp and other data to make the calculation. With enough data they "should" be able to be fairly accurate, but I question the oil temp accuracy at the extreme ends of the scale or under more unusual circumstances.
Old May 17, 2011 | 10:24 PM
firehawk618's Avatar
firehawk618
Yup, you're right.
Old May 17, 2011 | 10:57 PM
Luys's Avatar
Luys
I have the same thing, my oil always shows on the chrono gauge a little high temp... on the track I saw 270F and on the street 170-190F. I use Castrol 10 - 60 oil and I have oil cooler... Is that normal? should I buy the M7 180 degree thermostat?
BRracing
Dec 22, 2015 09:25 AM
minicoclub
Nov 11, 2015 07:25 AM
bigserb3
Aug 31, 2015 09:54 AM
Bruce/Fl
Aug 28, 2015 11:59 AM
missinmyjeep
Aug 22, 2015 07:13 PM
