Drivetrain Boost Pressure Survey
Old Jun 19, 2009 | 08:33 PM
  #26
ThumperMCS's Avatar
ThumperMCS
Originally Posted by unclemeat
MAP on the ODB port would be about 34~35 for 20PSI. Basically MAP minus atmospheric pressure (about 14.7) gives you boost preassure.
I do have to comment on how grosely slow and generally inaccurate a ScanGauge actually is.
I do have a basis for comparison from seeing a maximum of 13.5PSI on my old 2008 S - Stock on the same scangauge.
Why do you say the scanguage is inaccurate?
If you set it up to display Boost Pressure through X-Gauge and enter the proper value for the current airpressure at your given altitude...its fairly accurate. I will give you that it can be somewhat slow...but it still gives you an accurate picture of what boost your car is running.
Helix13mini
Jul 27, 2016 06:29 PM
daviday
Sep 25, 2015 01:31 AM
Sep 16, 2015 02:10 PM
Sep 16, 2015 02:09 PM
Sep 2, 2015 11:15 AM
