Drivetrain What is your take on Dynolicious?
Old May 30, 2009 | 09:14 PM
  #26
MUShadd's Avatar
MUShadd
I am going to the dragstrip on 6/6 (saturday). I will try to do a few runs with dynolicious...just to see how it matches to the track timer.
Old May 30, 2009 | 11:56 PM
  #27
Luys's Avatar
Luys
Yesterday, I ran the Dynolicious I've got these results: 130HP and 0-60 4.73 . How could be a 130HP gave 0-60 4.73??? When I saw the 4.73 I thought I am driving 911.
Old May 31, 2009 | 06:02 AM
  #28
ofioliti's Avatar
ofioliti
That'll be nice! Let us know the results!
Old May 31, 2009 | 11:06 AM
  #29
MUShadd's Avatar
MUShadd
did you have wheel spin or anything? thats the only time i get awkward readings.
Old May 31, 2009 | 11:16 AM
  #30
ofioliti's Avatar
ofioliti
.. or the iPhone was not mounted rigidly(?)
Old May 31, 2009 | 12:17 PM
  #31
kapps's Avatar
kapps
130HP and sub 5 sec 0-60? Do you have the weight entered right?
Old May 31, 2009 | 07:37 PM
  #32
MUShadd's Avatar
MUShadd
yeah, forgot bout that. doesnt work well if you sit it in your lap or in your seat.
Old Jun 3, 2009 | 09:08 AM
  #33
mininuke's Avatar
mininuke
The accelerometer in the iPhone calculates the hp by the following:
Force = mass X acceleration (hence you need to provide it with the mass of car+driver)
Work = force X distance
Power = work / time
So assuming the weight that you enter is correct, then in theory it should be giving you the actual power that you are putting to the ground to make the car accelerate. So if your launches are poor (you spin the wheels) and/or inconsistent, then the iPhone will be calculating a different HP from what you may have gotten from a dyno, say.
When you say it is "not giving an accurate reading" what are you comparing it to?
I'm comparing the number to actual dyno results.
Old Jun 3, 2009 | 09:24 AM
  #34
ofioliti's Avatar
ofioliti
Ah, OK.
Assuming the dyno results are accurate and the accelerometer is accurate, then the factors that would cause a disparity in HP results would be:
(a) improperly mounted iPhone (it doesn't move exactly with the car)
(b) driver is not driving the car at its maximum acceleration capacity
(c) wheels are spinning instead of grabbing the road and moving the car
Once you are satisfied with the HP you have through mods/tunes as verified by a dyno check, then Dynolicious is a great way to check upon the other factors that make the car go fast (rubber and driver).
Old Jun 7, 2009 | 04:58 AM
  #35
bratling's Avatar
bratling
Super Moderator
Found some HP advice from Dynolicious's developer!
So far I haven't been able to get an accurate HP reading.
for what it's worth ... last night i was browsing the Dynolicious.com forums and found a thread in which the developer offered this advice:
In my experience, you'll usually find your peak horsepower with Dynolicious in 2nd gear. This is where most of the variables are limited. If you are looking to get a good horsepower run you'll want to ease into first gear and try not to jerk too much on launch, shift early into second, then floor it (although every car is different, so I won't say this is the best for everyone).
[...snip...]
You should be able to see where the peak HP is being generated. If you're seeing peak when you launch the car, it's probably because of the initial shock of the launch, and not the true HP of the engine.
Hope this helps!
Old Aug 6, 2009 | 08:30 AM
  #36
bratling's Avatar
bratling
Super Moderator
Update:
Last weekend I attended an autocross school (my first time ever). Did a couple runs with Dynolicious running, including a run in a friend's 911. My Cooper S was running with stock all-season runflat tires and the heavy 17" crown spoke wheels.
Screenshot of the app at the end of a run, skidpad mode:
Skidpad graph:
Skidpad graph for my friend's 911:
Love this app.
Old Aug 6, 2009 | 07:52 PM
  #37
Fatherdeth's Avatar
Fatherdeth
What are you guys using to mount the iPhone or touch to the car? I have dynolicious on my iPhone, but haven't used it yet. I would like a decent mounting system.
Old Aug 7, 2009 | 05:25 AM
  #38
gilll7's Avatar
gilll7
just got the 3gs and the app today
what do you guys enter for drivetrain loss % ?
Old Aug 7, 2009 | 05:26 AM
  #39
bratling's Avatar
bratling
Super Moderator
Believe it or not -- the cup holder in front of the shifter. Those little rubber tabs work great to hold my iPhone without moving. I make sure the center two tabs (left and right) are on top of iPhone, holding it against the rear of the cup holder (where "rear" means "front end of car", sorry for any confusion).
I'm sure this wouldn't work for an F1 car but for the sort of G's I can pull in a Mini, it works great!
Old Aug 7, 2009 | 05:28 AM
  #40
bratling's Avatar
bratling
Super Moderator
Can't help you ... I'm just using it for skidpad, not straight-line measurements. If you set drivetrain loss to 0% then you will get actual wheel horsepower. Not sure what correction factor to use to try to get crank power. Maybe one of the other guys here can help.
Old Aug 7, 2009 | 05:39 AM
  #41
gilll7's Avatar
gilll7
thx bratling ..
also how much is the total weight of a r53 .. if you look up the specs do these include the fluids (it never states if it it's the dry or wet weight)
who here has actually been on a weighbridge with his r53 ?
Old Aug 7, 2009 | 06:30 AM
  #42
MUShadd's Avatar
MUShadd
There is an actual iphone windshield mount that i use. it has pivoting arms and mounts securly to the car. You want something that will be as stable as possible and yet not provide any cushioning from car movement. I bought mine from Best Buy for around $30.
put in 0 for the drivetrain loss. that will put your calculations in WHP format, which is what counts. IF you enter a drivetrain loss percentage, then it will simply take your WHP and multiply it by that percentage to give you BHP...or crank horsepower. Drive train loss varies by every car but 13-14% seems to be the agreeable range for r53s.
thx bratling ..
My MINI tipped the scales at 2900 lbs with a full tank of gas, and me sitting in it.(im 200lbs) I have a heavier MINI since i have the Xenons, sunroof, h/k, etc. Go to a truck stop. I stopped at one with Cat Scales. I think it was about $8 to get weighed. the fun part is driving onto the deck and having to jump up in the air to push the button (its mounted high so truck drivers can press it from their cab.) Of course you can estimate your weight, but going to a scale with make sure your results are just that more accurate.
Old Aug 7, 2009 | 06:39 AM
  #43
raoul_duke's Avatar
raoul_duke
I've had pretty good results putting my iphone in the ashtray. With the ashtray in a front cup holder, and the top flipped open towards the front of the car, I then put a rubber band around the iphone and the ashtray lid thats behind the iphone.
Keeps it nice and solid and I can easily access the buttons on the phone.
Old Aug 8, 2009 | 09:34 PM
  #44
Fatherdeth's Avatar
Fatherdeth
Bratling, Raoul, and MUSHadd. Thanks for the advice guys.
MattF NYMC
MINI Camera and Video
Aug 9, 2008 05:03 PM
stan11003
Jul 29, 2008 08:46 PM
