Drivetrain Cleaned IC after 160,000 miles...
Old May 11, 2009 | 05:52 AM
meb's Avatar
meb
...and I was quite shocked by how clean it looked. I used a cleaning solution - poured it in the intake side a number of times and what came out was dirty, but far less so than I expected.
The boots collected quite a bit of oil in their recesses. All in all a very easy job that made no apparent difference in performance...perhaps the rest of the intake tract is dirty
I didn't have time to get to the throttle-body...
Old May 14, 2009 | 11:09 AM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
Thats quite a large number of miles! What kind of stuff have you fixed/replaced?
Old May 14, 2009 | 11:21 AM
onasled's Avatar
onasled
Oh God, don't ask him that!
Meb, did you wash acetone through it?
Old May 14, 2009 | 11:46 AM
Vernon29RW's Avatar
Vernon29RW
I sprayed about 3/4 of a small can of throttle body cleaner through the IC after 40,000 miles and only got a little bit of stuff out. It was mostly just the cleaner a little oil mixed in it. Even before I sprayed there was only a thin film that probably could have just been wiped out but I decided to run the cleaner through in case any had made its way deeper into the IC that I could see from the end tanks. Then I installed a catch can to hopefully catch anymore oil vapor before it gets back in the IC
Old May 14, 2009 | 12:06 PM
xsmini's Avatar
xsmini
Lotsa winshields
Nik
Old May 18, 2009 | 11:28 AM
PenelopeG3's Avatar
PenelopeG3
It also helps to spay water through the IC fins (and rad and a/c condensor) to get the years and miles of dust that accumulates there. Airflow through the fins are important for heat transfer.
OutMotoring
Mar 3, 2017 06:29 AM
bahman
Feb 14, 2016 10:29 AM
simo711
Oct 8, 2015 07:07 PM
Sep 29, 2015 12:11 PM
EVMini
Sep 28, 2015 10:20 AM
