Drivetrain Mynes R53 parts testing results (an upgrade "guide" to your MCS?)
#226
on
Yep - for equal length primaries... makes a TON of difference in how the car performs (and sounds) - truly sequential flow of exhaust pulses vs. collisions in the collector yields smoother flow and more consistent pressures. I'm running "the other" equal length header - nice to see more options coming to market.
Wish I had the jetcoat... nice stuff!
We didn't want any potential exhaust leaks with our design so we made it with bigger ports and did the following:
- insert the runners thru the ports to match the gasket perfect;
- tap the inside of the runners to fit around the inside of the ports;
- weld the inside where the runners meet the ports
- sand and smooth the port channels for perfect airflow
- weld the outside where the runners meet the flange
- sand down and straight-edge the flange for a tight/flat seal to the head
Not to toot my own horn but we thought about just everything and done all the tricks to make the header look good and perform good all the same time
#228
on
NONE at this time. I've had mine in the car for 3 days thus far with no CEL. The same cat has been used in headers for other cars with similar good results.
- header ~ 9whp/9tqe
- 15% pulley ~ 10whp/9tqe
- intake ~ ?
- Exhaust ~ ? (i'm guessing about 5hp, will let you know once i get mine )
- Custom tune ~ varies from car to car... but this is the critical factor. Parts can give you more power/torque, but a tune is needed to harvest MAXIMUM power potential of your car. The stock ecu has a limited range of how much it can compensate.
FYI: i'm taking my E85 from Phx to Vegas ~350 miles. There are three E85 stations near the Palace Station hotel where i can fill up, and there's one on the way at Kingman (roughly half-way point). I'll bring a 5-gallon jug with me just in case i get detoured It's not that bad... plus you're in corn-country, i'm sure there will be more stations popping up soon enough.
#229
Partsman, if you want more power to compete with the boys, then i'd definitely suggest the good Dr's turbo manifold The twin-charge is a cool design and very quick (TULS TC Mini for instance can keep up with an E55 AMG pretty much, but that was on race gas), but i'm leaning towards the simple/practical single turbo setup. Keep an eye out for the upcoming turbo build that we'll be doing for the "Green Machine"... we are going to add a little twist to the mix and see how our turbo setup compares to the Garrett GT28/30r setups that have been done thus far on Kal's, Joel's, Brian's and Johnny's. Hubie likes the idea and wanted to give it a shot as well
I always thought the TC was cool too...I figure i'd run that for a while and have some fun, and build a stronger short block in the mean time for some serious power later on.
#232
So if it was normal gas you would be at:
216whp/178ftlbs with the header + cat.
Or the below with E85 and E85 + the header + cat.
234 184 15% Pulley with Bosch 550cc Injectors + Shrick Cam + E85 Fuel
239 189 15% Pulley with Bosch 550cc Injectors + Shrick Cam + E85 Fuel + MegaMynes Header (Cat version)
So the header made 5whp and 5ftlbs.
Why make a non-cat version? The M45 cars are totally un-livable without a cat. Isn't running cat less and E85 an oxymoron ?
Longboard
Longboard
#233
Mike did you do any cat out vs cat in dyno's?
Do you have a pic of the step header?
Longboard
#234
Well if it's not to load for you then I guess it's livable. Do a search here and you will find lots of people who did it only to go back because of how load it was. On top of that most agree there is no HP gain going cat-less.
Longboard
Longboard
#235
on
Well, thanks to Longboard, according to the US Department of Energy, Indiana has 101-200 stations. Unfortunately, there aren't any in my town, which is puzzling as we have a refinery (?) or distribution center... There are however several within any direction of the city (10 minute drive to each). So not bad. I'd just have to make sure I fill up whenever I go by them. Can't wait to see what you guys come up with next!
#236
on
Pics of the "Stepped-header" updated in Post #7.
The Test-pipe did not provide any add'l power vs the high-flow CAT. Based our results, there are only two reasons why one would choose the test pipe (IMO):
- if you're racing the car at the tracks using Leaded fuel; or
- if you want the car to be a little louder.
The high-flow CAT performs great with no CEL ... can't ask for more than that
#237
Longboard
#238
From what I've read in this thread about E85 the octane rating is that of race gas, and I would assume that tuning on race gas will produce higher gains from all modifications. For those of us in Cali who don't have access to an E85 station, would you be able to show some dyno charts of your parts using 91 octane?
#239
on
On a turbo car, that's a different story... we can probably up the boost and run 23 or 26 psi b/c the higher octane fuel etc... that's goes back to the same efficiency under the curve argument that i do not wish to address at this time - we all know what a can of worm that can turn into
#240
I was under the impression that higher octane gas improves power for both forced induction vehicles and high compression naturally-aspirated engines. What I'm reading from this post is that high compression or forced induction vehicles don't benefit from high octane gas unless it's "tuned" for, is that correct?
The higher octane rating means that it requires more compression before it detonates is that not correct? Isn't this also the reason why it's not recommended to put low octane gas into our engines, as it will cause pre-detonation and ultimately cause the car to go into limp mode. Can you evaluate further on my question as I'm pretty confused now...
Also wouldn't high octane gas change the delta if it requires more compression before it detonates?
Thanks for taking the time to answer my questions!
It's all in the "delta"... We know E85 is higher octane so it's going to make more power than 91 octane (Post #5, the net gain from E85 was 23whp and 11wtqe). So if you remove this delta, that's the approx power on 91 Octane.
This would be true on a turbo car. But on a SC Mini, we can't raise the boost level on the spot so the higher octane has less direct effect. The torque numbers don't move unless you change something mechanical that alters the Torque (i.e. Cam, pulley or header).
#241
on
=> higher octane = ecu adjusts for more aggressive timing = a little extra power
=> higher octane = ecu adjusts for more aggressive timing + tuning = more power + a little more.
=> higher octane = ecu adjusts for more aggressive timing + tuning + extra BOOST = Extra extra power
Higher octane does not automatically give you more power. It ALLOWS your car to make more power by adding more timing and leaning out the AFR and run higher boost.
If you want to do an experiment, do this: Put some 87 octane in your car, go drive around town for a bit. The ecu is going to pick up more knock with the lower octane and retard timing = which means your car loses power. But there's a limit on how much timing the ECU can pull back. If you keep beating on it, the ecu is not going to compensate for it and your motor will eventually go boom...
cheers.
#242
Oh I see, so that means that the E85 fuel is allowing you to run a more aggressive timing from the tune which results in more power?
Here are the "simplified" answers:
cheers.
cheers.
#243
on
#244
#245
#247
on
the delta is 23hp and 11tqe, check out Post #9 for some Test numbers on 91 Octane
#248
I was under the impression that advancing the timing is by degrees, so its possible to advance the timing to a point where if 91 Octane were to be used, it would pre-detonate and cause a whole lotta issues. Can you post the charts of the cars that you tuned? I'd like to see the delta on those, and if possible see how much power the MegaMynes header makes on 91 Octane gas.
#249
on
#250
Here are some of the results on 91 Octane Shell Gasoline. I will update the graphs after AMVIV - trying to pack things up right now)..
Customer #1)
2004 MCS with 17%; Milltek, 550cc Bosch; Newman Cam, RMW header; 228whp/189wtqe
Customer #2)
2005 MCS with 550cc Bosch, 15%, CAI, Milltek, 222whp/175wtqe
Customer #3)
2004 MCS with 15%, 2% crank, OBX header, Bosch 550cc, Shrick Cam, MegaMini Stage I Head, electric waterpump, aftermarket exhaust (forget what kind) = 244whp/179wtqe
Customer #1)
Customer #2)
Customer #3)
