Drivetrain Supercharger intake tube... help!!!
Old Mar 6, 2009 | 05:37 PM
agoodsign's Avatar
agoodsign
Aaaaaargh.
Installed a DT BPV tonight, pretty sure I broke the supercharger tube. Car revs wildly on startup and then idles obscenely rough.
Is there anyway to fix it, even temporarily, to make the car drivable until I can get my hands on a new tube on Monday, or am I screwed?
Old Mar 6, 2009 | 05:41 PM
jeffc's Avatar
jeffc
7th Gear
Ouch I know it is a ***** to replace it.
Old Mar 6, 2009 | 05:57 PM
jhiggs26's Avatar
jhiggs26
Put it into service mode. Get duct, fore and aft gaskets, then you'll be good to go!
Jeremy
Old Mar 6, 2009 | 06:12 PM
agoodsign's Avatar
agoodsign
Jeremy
No temporary fix until I can get the duct though? Duct tape? Cable ties? Fruit cake?
Old Mar 6, 2009 | 06:21 PM
jhiggs26's Avatar
jhiggs26
You can try epoxy or something with duct tape on top but if the cheapo plactic duct is cracked it's best to replace it of course.
Also check the vacuum line that runs in to the top of duct. You may have disengaged it to cause a leak while installing your DT BPV. Small hands go a long way in there. Good luck!
Jeremy
Old Mar 6, 2009 | 07:48 PM
agoodsign's Avatar
agoodsign
Woo Hoo! Got it to work! It's rigged but it seems like it'll hold at least as tight as it did from the factory. I'm not too impressed with this bit of German engineering, what an incredibly weak little piece of plastic. Geez.
Most of the tab was still in tact, just the very end had broken off, so I drilled through the tab (not into the tube...) and rigged up a small cable tie to go through the hole and wrap around the bolt (which I backed out a bit more). Pulled it snug and when I bolted the throttle body back in place I could not budge the supercharger tube no matter how hard I tried. I'm going to let it ride for a while, if it holds I'm not going to replace it, that was noooooooooooo fun getting even my below-average sized hands down in there.
Old Apr 12, 2015 | 04:45 AM
Minibeagle's Avatar
Minibeagle
Gah! Same thing happened to me last night
Things were going too smoothly with this repair
patsum
26
May 29, 2021 06:29 PM
larryd96
11
Sep 8, 2015 05:01 AM
eliseo1981
Sep 4, 2015 02:33 PM
Sep 3, 2015 03:01 PM
M7Speed
Sep 3, 2015 07:48 AM
