Drivetrain 303whp 248wtq 16 psi 91 octane
Old Feb 24, 2009 | 05:43 PM
  #76
cartar452's Avatar
cartar452
Originally Posted by UKSUV
So Im curious to what you are trying to say here?
www.youtube.com/watch?v=S6CGmxKEGow
Old Feb 24, 2009 | 05:59 PM
  #77
UKSUV's Avatar
UKSUV
Originally Posted by cartar452
Ah...you threw me...I was like WTF was that....lmao
Old Feb 24, 2009 | 06:01 PM
  #78
cartar452's Avatar
cartar452
haha yeah my bad
Old Feb 28, 2009 | 02:01 AM
  #79
J_'09s's Avatar
J_'09s
yall know of any 2nd gens with builds of this caliber here on nam? thanks
Old Mar 3, 2009 | 07:11 AM
  #80
Mike@Mynes's Avatar
Mike@Mynes
Not that we are aware of. The limiting factor seems to be the stock ECU at this point in time.
Old Mar 3, 2009 | 10:07 AM
  #81
ThumperMCS's Avatar
ThumperMCS
Have you guys tried to tackle it at all? Everyone is getting impatient for a decent tune...
Old Mar 4, 2009 | 08:06 AM
  #82
Soul Coughing's Avatar
Soul Coughing
congrats man on the numbers!
Old Mar 4, 2009 | 09:45 AM
  #83
jaytech's Avatar
jaytech
We are tackling at it. Just alot more complicated since BMW changed their tooling for reflashing the stock ECU thru OBD II port. It gets all the information from a server once it pings your ECU VIN, coding information. Then the encrypted data comes from the server into your ECU with the password unlocked. Once done, the server locks the ECU again. And this password all depends on the vehicle's VIN and coding information to unlock the ECU. Which means everyone's ECU has a different password since VIN's are different. But once you break this password encryption, we can figure out to flash thru OBD II on every R56 until BMW changes to another algorithm, and the process starts all over again..lol
As I type this post, we are working on right now, I have the code and we are disassembling the code now to figure out the encryption to flash through OBD II. We found most maps already to tune the ECU.
Jason
MYNES/ABF
Old Jun 15, 2009 | 01:31 PM
  #84
kalbone's Avatar
kalbone
short clip of my car.
http://vimeo.com/5134864?pg=embed&sec=
Old Jun 15, 2009 | 01:37 PM
  #85
malteseracer's Avatar
malteseracer
91? Thought you were supposed to run 93 in Coopers. At least S models with a turbo
Old Jun 15, 2009 | 01:41 PM
  #86
checkmate2006's Avatar
checkmate2006
WOOOHOOOO actual video of your car
Old Jun 15, 2009 | 01:42 PM
  #87
checkmate2006
91 is the minimum for the S both R53 and R56
Old Jun 15, 2009 | 02:37 PM
  #88
Mike@Mynes's Avatar
Mike@Mynes
Here on the Left Coast the highest octane at the pump is 91 :(
Old Jun 16, 2009 | 06:08 AM
  #89
J_'09s's Avatar
J_'09s
we have 98 octane out here in Spain!
Old Jun 16, 2009 | 08:25 AM
  #90
ca$per's Avatar
ca$per
You should use whatever grade/octane the owner's manual recommends.
I recommend reading the US Federal Trade Commission's Facts for Consumers - "The Low-Down on High Octane Gasoline"
http://www.ftc.gov/bcp/edu/pubs/cons...tos/aut12.shtm
If your vehicle is experiencing engine knock (or pinging), then you should go up a grade in octane. (But if your vehicle is fairly new and has engine knock, something else may be wrong and you should seek a tune-up!)
Octane is a measure of the fuel's ability to resist pre-detonation (or engine knock). It burns just a little bit slower.
Higher octane gasoline doesn't mean that it is necessarily cleaner or better. "Premium" or "super" is a mis-nomer. All gasoline sold in the US must meet certain federal EPA clean-burning guidelines. However, some individual brands _may_ decide to put some extra cleaners or do extra refining in their higher-octane fuel (as I've heard of some brands advertising low-sulfur gasoline as only in their Premium line).
A higher octane gasoline actually has lower BTUs (energy content) than a lower octane gasoline, so the only way that you'd see better fuel economy by going up in octane is if you were previously using lower than recommended octane in your car... (So expect lower fuel economy in most vehicles by using higher than "regular" octane gasoline.)
For an occasional tank, you could get away with using a lower octane than recommended in a vehicle that requires "premium" fuel, as the car will adjust, but it can cause some extra wear on the engine while knocking, besides the lowered fuel economy. (long term use can cause additional engine wear/damage)
If you live in a high altitude area (like the Rocky Mountains) usually you can use the next octane level down from what is listed in the owner's manual because of the altitude/thin air with no ill effects (except if you come down from the altitude with a full tank!).
For some cars, such as the Toyota Prius, using higher than the recommended octane fuel is known to cause check engine lights with engine misfire codes (because of the Atkinson cycle engine, rather than the Otto cycle engine most other cars use) due to the late detonation, besides the expected lower fuel economy.
Reasons to use higher octane fuel:
1. Your owners manual calls for it
2. Your engine is knocking
3. It's the only way to get low-sulfur fuel in your area (sulfur will slowly poison your catalyst, making emissions worse over time)
4. You like spending extra money on gasoline
See also:
Premium vs. Regular: Premium vs Regular
MYTH BUSTING: High Octane fuel will make a car faster (June 2008): Myth Buster on High Octane
Types of Fuel and Octane Ratings: FUEL RATINGS
Now back to Calbone's 303hp monster
Cheers,
Old Jul 3, 2009 | 10:10 PM
  #91
dustinhxc's Avatar
dustinhxc
NICE!!
Old Jul 5, 2009 | 02:43 PM
  #92
04indimcs's Avatar
04indimcs
Originally Posted by kalbone
Kalbone you got any more clips?
Old Jul 5, 2009 | 03:04 PM
  #93
J_'09s's Avatar
J_'09s
AWW i tried to watch your video and it was removed for use violations, leads me to believe it was an awesome video lol
Old Jul 6, 2009 | 09:51 AM
  #94
kalbone's Avatar
kalbone
not yet..
video still there...
Old Jul 6, 2009 | 12:49 PM
  #95
batrugger's Avatar
batrugger
98 in Europe = 91 in USA
Old Jul 6, 2009 | 02:06 PM
  #96
Partsman's Avatar
Partsman
Legion_of_Doom
Cool vid, kal.
We need to see and hear your car in the next one.
Old Jul 6, 2009 | 06:55 PM
  #97
J_'09s's Avatar
J_'09s
Really? That's wierd. Luckily i've been using the base gas...
Old Jul 8, 2009 | 05:25 PM
  #98
AZblackOUT's Avatar
AZblackOUT
Originally Posted by Partsman
Cool vid, kal.
Yeah, but you can hear mine
Old Jul 8, 2009 | 06:17 PM
  #99
Partsman's Avatar
Partsman
Legion_of_Doom
Damn man, I knew that car looked familiar! Very nice!
Old Jul 8, 2009 | 07:27 PM
  #100
04indimcs's Avatar
04indimcs
Cool vid, kal.
Agreed
