Drivetrain CEL question
Old Jan 23, 2009 | 02:43 PM
parisinfire's Avatar
parisinfire
CEL question
well I finally got the p0420 code to go away with the spacer now I am getting 3 new ones
p0141
p115d
p0136
All dealing with th eo2 sensor in the 2nd bank. I am guessing I need to replace the o2 sensor at the bottom of the DP anyone have this problem and know where to buy new o2 sensors?
Old Jan 23, 2009 | 03:06 PM
scott48's Avatar
scott48
I had the p0141 and p115d, when I cleared it today there was only the p0141 tho....I'm wondering about specific cause also and what's the solution, if it's replacing that O2 sensor or what.
Old Jan 23, 2009 | 06:21 PM
parisinfire
Yah this sucks I might just get o2 sensor and see how that works the codes are for malfunctioning heat and circut for the o2 sensor.
Old Jan 23, 2009 | 06:42 PM
scott48's Avatar
scott48
yea i'm gonna try some stuff, i'll let you know if anything works
Old Jan 24, 2009 | 03:21 AM
coopman7's Avatar
coopman7
If you guys have spacers on your O2 sensors i would take them off and see how you get on as from what i hear the O2 sensors only seem to throw CELs when they dont warm up quickly enough..
Old Jan 24, 2009 | 06:53 AM
parisinfire
Yah man let me know ill let you know also. Well without the spacer it throws p0420 codes I would love to smash minis super sensitive computer!
Old Jan 24, 2009 | 10:41 AM
scott48's Avatar
scott48
I just took the spacer off the 2nd o2 sensor, so we'll see what happens.
Old Jan 24, 2009 | 02:25 PM
scott48's Avatar
scott48
well just got back from driving for like an hour after having removed that spacer from the o2 sensor, and no cel came on, I was glad.
Old Jan 24, 2009 | 03:51 PM
parisinfire
Yah hey do you have a spacer on your top o2 sensor I just put one on the bottom of the DP
Old Jan 24, 2009 | 04:08 PM
scott48's Avatar
scott48
nope never did, just on the 2nd o2 sensor cuz it's after the cat, but don't have that any more and no cel
Old Jan 25, 2009 | 04:44 AM
coopman7's Avatar
coopman7
Nice one Glad it worked out, fingers crossed that you dont ever get any CELs!
Old Jan 26, 2009 | 07:13 PM
scott48's Avatar
scott48
after driving more the cel came back on, and its the p0420 "cat efficiency below threshold" this time...i cleared it again
Old Jan 26, 2009 | 08:18 PM
parisinfire
GOOD LORD so tis either one CEL code or 3 hmmmmm cant wait to try to get my car to pass emmisions =)
Old Jan 26, 2009 | 11:25 PM
SlowB00st's Avatar
SlowB00st
The P115D has nothing to do with the cats its for
"Mass or Volume Air Flow 'A' Air Mass Too High Compared to Model"
Also has anyone tried electronically modifying the sensor signal with a resistor and capacitor? I did this on my previous toyota matrix and also friends cars with great success.
If you don't want to modify the sensor wiring how about welding a bung higher in the downpipe (hotter spot) if there is enough cable for it, so that it does not trigger the P0141 after using the spacer.
Old Jan 27, 2009 | 02:09 AM
hopper's Avatar
hopper
I have an Altal dp and exhaust with one spacer and get occasional 2270 cels on the highway. Not sure what that one is.
Old Jan 27, 2009 | 03:59 AM
fernflex's Avatar
fernflex
I have seen this one in my car also.
P2270= 02 sensor signal stuck lean, bank 1 sensor 2
Old Jan 27, 2009 | 04:47 AM
hopper's Avatar
hopper
Seems to be more often now that we have colder weather here in the East, and only seems to appear when at cruise on the highway. To be clear, I have the Alta downpipe with a double bolt/spacer.
Old Jan 27, 2009 | 10:15 AM
parisinfire
Hey hopper when you say you only have one spacer do you mean just on one o2 sensor or do you mean one of those "screwin" things and not both because alta sent me 2 and I have them both on the one 02 sensor.
Old Jan 27, 2009 | 10:33 PM
AkFarina's Avatar
AkFarina
the way the o2 sensor reads after the dp is by temp try moving it farther away by extending the wires so the temp it reads is the same it would be with the stock dp and stock local
Old Jan 28, 2009 | 07:39 AM
coopman7's Avatar
coopman7
Or just save yourselves all the bother of CELs and buy a Ragazzon decat downpipe and put the O2 sensors back in as normal with no spacers and walla
Old Jan 28, 2009 | 08:37 AM
parisinfire
Yah well for the 800 or so I spent on ALTA I wished it would work right.
Old Jan 28, 2009 | 12:47 PM
Xray'dit_Mini's Avatar
Xray'dit_Mini
exhaust wrap
Has anyone tried to use and exhaust wrap around the downpipe to keep the temps up, and in turn heating the O2 sensors better???
Old Jan 28, 2009 | 02:29 PM
Ryephile's Avatar
Ryephile
Why are you guys having CEL's at all.....no catalytic converter, or just one that doesn't work but is called a "cat"? From what I can gather, only people with the ALTA downpipe and/or the UNIchip are having CEL issues, right?
Has anyone with these issues tried finding root cause? Remove the UNIchip, clear any codes, and drive. If that doesn't cut it, put the stock exhaust back on and repeat. It's entirely possible that the cat ALTA uses is so "high flow" that it does not sufficiently alter the AFR read by the downstream O2 to appease the ECU. Ditto the UNIchip altering sensor signals. Bottom line is whatever your setups are, they do not appease the stock ECU.
Old Jan 28, 2009 | 04:33 PM
scott48's Avatar
scott48
and now that p115d randomly comes on....and these all have come on without the unichip...and so what would cause the p115d, (i know what the technical definition is) and cuz when it comes on is when coming to a hard stop it'll try and stall or actually will, pretty retarded.
Old Jan 31, 2009 | 04:45 PM
parisinfire
This sucks where is ALTA on all this hahaha.
