Drivetrain When installing the tsw v2 damper...
Old Jan 21, 2009 | 10:20 PM
mach schnell's Avatar
mach schnell
i'm gonna try to install my v2 later this week. any bits of advice for overcoming any little obstacles during install?
seems like i recall a thread (but i didn't find it or was half awake when i read what i found) something about a string or something tied to one of the bolts so as not to lose it.
anyway, any help or advice will be greatly appreciated to make this as smooth and easy as possible. thanks
Old Jan 21, 2009 | 11:47 PM
glnr13's Avatar
glnr13
the string technique was for the LOTF damper, different location.
I have a TSW earlier versiondamper. their instructions are easy to follow with pics. should be enclosed in the package, if not I know it's on their site too.
Old Jan 22, 2009 | 08:28 AM
mach schnell
yeah - i've read thru the instructions a few times and taken a few looks at the engine compartment just to get a good visual before i embark on this. it just looks like that one 16 mm bolt by the frame rail behind the large,
cast aluminum engine supporting bracket (step 1) being way down there crammed in a little spot might be an easy thing to drop into the inner depths of the engine bay. i would using a pipe cleaner or wound up piece of paper if the bolt was hollow to help prevent dropping/losing it.
anyone had difficulty with that?
and, i don't have a torque wrench - will that be a prob?
Old Jan 22, 2009 | 08:12 PM
Some Guy's Avatar
Some Guy
Everybody should have a torque wrench if they plan to work on there own car. It's one of those tools that when you need it nothing else does the job. And if you arent doing super precise work a fairly inexpensive Craftsman or Husky wrench will do the job.
Old Jan 22, 2009 | 08:19 PM
mach schnell
so, looks like i'll either be buying or borrowing one before i complete this mod
Old Jan 23, 2009 | 07:28 AM
thulchatt's Avatar
thulchatt
Agreed on the torque wrench but you can go even cheeper at Harbor Freight. I have both the 1/2" and 1/4" and they both work well. They probably will not last like Craftsman or Husky but I only paid about $10 for each.
Old Jan 23, 2009 | 08:09 AM
mini_racer's Avatar
mini_racer
I would not trust the accuracy of a Harbor Freight torque wrench. Don't get me wrong, I like HF and have purchased many things from them, but proper torque settings are too important for HF, stick with the Craftsman or Husky as mentioned.
Also, on the TSW V2 engine damper, I just installed one myself. It works well, and the preload adjustment does actually increase the firmness. However, expect some additional whine/noise if you firm it up too much. Not a good whine like from the SC, more of a noise. I did not experience additional vibration.
As far as fitment, I had to grind off some of the engine side bracket as well as the new supplied fuels breather valve bracket. Both of these brackets simply did not fit, I had to adjust them significantly such that they would clear the SC horn. I then touched it up to make sure it would not rust. This was disappointing.
Hopefully, you will have better luck and can install with no modifications.
Old Jan 23, 2009 | 08:47 AM
MUShadd's Avatar
MUShadd
Color pictures helped me when figuring out which side/end each conical,washer,nut went. black and white in the directions left a lot do be desired. I had the V1, I hated it, then went with V2 and it was much better....until the bracket bent on it. I have now moved on to the VIP damper. We'll see how long it lasts.
Old Jan 23, 2009 | 08:58 AM
AutoXCooper.com's Avatar
AutoXCooper.com
I have asked TSW to address your install issues. They or I will post the a reply ASAP.
TSW will replace the early brackets that bent. They later brackets are thicker and have not bent like the early ones. I also bent my 1st gen setup on my R50 but have had no issue with the 2nd gen front bracket.
Old Jan 23, 2009 | 10:04 AM
MUShadd's Avatar
MUShadd
That they did. Their customer service is superior to every place ive experienced. However, I bent my second "v2" bracket too. I guess I just have a mean car, lol.
Im sure i'll have better luck with their springs when I get around to buying them.
Old Jan 23, 2009 | 01:07 PM
Spooled's Avatar
Spooled
I just installed a TSW V2 damper a couple weeks back. Install took me about 15 minutes. It was extremely easy. As for the bolt down on the frame rail - I didn't have any problems, but if you're worried, just get a small telescoping magnet and have it against the bolt while you're removing it. Everyone should have one of those telescoping magnets. It's one of the most valuable tools in my arsenal! Good luck!
Old Jan 23, 2009 | 03:02 PM
mini_racer's Avatar
mini_racer
And so what's the word?
Old Jan 23, 2009 | 04:55 PM
AutoXCooper.com
None yet, I know they had a ton of orders to get out today. I bet I hear from them this weekend and will post it at that time.
Old Jan 23, 2009 | 07:39 PM
mini_racer's Avatar
mini_racer
Thanks and I will be on the lookout. It was definitely an unexpected complication for an otherwise, simple installation. The easy solution was a little grinding and a little touch-up paint.
Once installed though, it works properly and looks good.
Old Jan 23, 2009 | 11:02 PM
Boxcars's Avatar
Boxcars
a telescoping magnet like spool said and
a telescoping mirror to find where that bolt dropped to
boxcars
Old Jan 24, 2009 | 09:13 AM
mach schnell
thanks for all the posts - i'm dying to put the thing in - just need to have access to a torque wrench and i'm all set. the local tuner shop down the street offered to loan me one after hours so as soon as i can work it into my schedule....and i'm hoping it only takes 15-30 minutes for the install. anything longer and i'm either dropping on the iq scale or i figure the install has gone terribly wrong.
Old Jan 25, 2009 | 10:12 PM
Boxcars's Avatar
Boxcars
mach
take your time,
the clock isn't ticking........
look at the pics on this site and in the instructions and "picture" the damper installed. ( actually hold it in place)
it takes as long as it takes,
you'll be fine
boxcars
Old Jan 25, 2009 | 10:23 PM
mach schnell
Originally Posted by Boxcars
mach
take your time,
you'll be fine
boxcars
installed it earlier this afternoon - went smoothly and i did it in about 45 minutes just to make sure i had it all together correctly. posted another thread about the results, if you have any comments there....
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
