Drivetrain TSW v2 engine damper install...
Old Jan 11, 2009 | 11:09 PM
mach schnell's Avatar
mach schnell
...hey, i know tsw has a pdf with pix on this, (i've looked at - maybe it's just that the pix aren't that great), but for those of you - (and by those of you i mean the wknd warrior modder, not someone like danny from minicorsa who could do this in his sleep) - are the instructions sufficient or is there a better way? we don't seem to have a how-to thread on this. just wondering if i'll be able to save the $50 to my local import mechanic and do it myself following their pdf - thanks.
Old Jan 11, 2009 | 11:22 PM
gnatster's Avatar
gnatster
Even 10 thumbs me that doesn't know a crescent wrench from a boxed end one can do this install.
Old Jan 12, 2009 | 06:28 AM
mini_racer's Avatar
mini_racer
I just installed one of these over the weekend. The install was straightforward, and the instructions were fine. Once installed the product does it's job fine and looks good.
However, I had to grind down two of the three brackets to make it fit. The provided engine side damper bracket would not clear the horn from the SC to the intercooler. Same story for the replacement fuel breather valve bracket. I just touched them up with a little Testors model paint so they will not rust.
I did not have to grind them much < 1/8 " each, and as there are manufacturing tolerances for the car and the damper, yours might fit perfect with no fitment issues.
Old Jan 12, 2009 | 10:03 AM
MUShadd's Avatar
MUShadd
I installed mine as well, the only confusing part for me was trying to figure how the location of the bolt, washer, conical, and nut and what order they went in and what direction they faced, if that makes sense. All i needed to help was a nice color close up to make sure i had it right.
Old Apr 15, 2009 | 08:03 AM
minimadness's Avatar
minimadness
Maybe someone could post a you tube video of a proper instillation.
Old Apr 15, 2009 | 11:43 AM
AutoXCooper.com's Avatar
AutoXCooper.com
For the early MINI
http://www.autoxcooper.com/pdf/MINI_...er_install.pdf
For the later MINI
Hope that helps, Dustin
W0TM8
Dec 19, 2019 07:50 AM
bobbiemartin
Jan 20, 2016 05:28 PM
aldito2
Nov 25, 2015 09:33 PM
Aug 21, 2015 10:41 AM
Emnotek
Aug 13, 2015 05:47 PM
