Drivetrain Alta BOV problems
Old Jan 8, 2009 | 10:22 PM
stinkytofu's Avatar
stinkytofu
Alta BOV problems
hello everyone, i just got my alta bov installed today and ive been having a few problems here and there. when i was driving the car harder than normal, the car's check engine light popped up. after driving normal for a while the check engine light disappeared. i had this problem come up more than once so i was just wondering if anyone has ever been in this situation? also after installing the bov the car seems to not ride as smoothly as it did before.
Old Jan 8, 2009 | 10:33 PM
scott48's Avatar
scott48
how is the car idling? about to stall or anything?...i've had it for awhile with no issues, just had to adjust it properly.
Old Jan 9, 2009 | 06:34 AM
stinkytofu's Avatar
stinkytofu
well there is still a small idling rev, but the most important was fixed..so no more stalls. im guessing the car has to adapt to the bov for a while before everything will be normal?
Old Jan 9, 2009 | 09:43 PM
got.pho?'s Avatar
got.pho?
how many miles are on it? time usually heals things =] we hope hah
Old Jan 9, 2009 | 10:27 PM
scott48's Avatar
scott48
Mine ran fine right away, just adjusted the spring tension to suit my needs.
Old Jan 10, 2009 | 09:23 AM
stinkytofu's Avatar
stinkytofu
the car has almost 20k. well, after 6 runs the spring tension is still a little off, cause after reving up to 4 grand the rmp kinda still drops a little bit. the check engine light is on now again, im having it checked out right after work =/
Old Jan 15, 2009 | 06:05 AM
XaLia's Avatar
XaLia
I have installed the bov 2 days ago i and i have exactly the same problem.
chack engine pops and then it disappears!!!
Any ideas??And the car at idle is fine no problems..
Scott how much did you adjusted the spring tension??
Old Jan 15, 2009 | 06:59 AM
scott48's Avatar
scott48
I had to add a decent amount of tension to the spring, screwing down on the cap...I'd say like 4-5 turns, but I did it so long ago its hard to remember
Old Jan 16, 2009 | 02:55 PM
FRATER's Avatar
FRATER
It happened to me and I had to take it off and re-installed it and then it was fine.. might be just a small vaccum leak.
Old Jan 16, 2009 | 05:11 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Hey guys,
Check the vacuum leads, and that it is secure in the boost tube. The spring really doesn't have to be that tight to even work properly.
BUT, if you have any questions or concerns PLEASE Pm me or ring our tech team! Always happy to help folks!
Chat soon!
MasterShaftner
Nov 4, 2016 09:38 AM
AWOL
Mar 28, 2016 10:51 AM
stierzy34
Sep 15, 2015 04:40 PM
theunlimitedone
Aug 31, 2015 08:17 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
