Drivetrain Aftermarket Bypass Valves and Fuel Mileage - why?
My wife has the CooperS, I am merely the pit crew and I am looking to buy a Detroit Tuned Bypass valve at MOTD this year for her birthday.
In other threads, people have mentioned installing a DT BTV vs. OEM affects fuel mileage, or the first question asked to someone who installed a DT BPV is "How much did it change your mileage?"
Why would an aftermarket bypass valve, from any vendor, make you lose mileage when compared to a correctly functioning stock valve? Both valves are supposed to hold the same boost pressures, just the Detroit Tuned does a better job of it (I think). I can understand having better mileage when unknowingly running a leaking bypass valve (as boost pressures are lower so there's less fuel required), but when comparing OEM new vs. DT new, mileage should be equal.
Right?
Right?
I think the deal is that aftermarket valves, along with sealing more completely, include a stiffer spring. This spring causes the valve to close sooner. Closed valve means more air into the engine, which means more fuel needs to be added to maintain correct A/F ratio, which results in lower gas mileage.
Right?
Right?
do a search for yo-yo effect , i am sure you will find a better explanation than i can give.
OK, I'll agree with that - I guess that spring being considerably stiffer would result in the car being "on boost" faster. I thought the spring would be more for holding the boost, but what you say makes sense.
Thanks for the quick response.
RatBlast,
Didn't even see your response last night - sorry to not acknowledge it. My wife's S does have a weakened valve which is why are changing it out. After meeting the folks from Detroit Tuned at MOTD last year they're getting my business - I just couldn't wrap my head around the reported drop in mileage.
RatBlast,
thanx for the reply
DWooderson
Aug 20, 2015 04:31 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
