Drivetrain RMW Header Awakens The Dead!
Old Dec 18, 2008 | 03:41 PM
  #26
MINI_chili's Avatar
MINI_chili
Originally Posted by agranger
Any hints on how they stiffened the exhaust hangers? I've got a whole lot of swing (melted the rear bumper valance at my last track day) on my Alta 2.5" single-sided exhaust (see the shiny picture in the posts above) that I'd like to dial out.
I've contemplated casting and pouring my own custom urethane MINI exhaust brackets, but that seems like a fairly extreme solution... someone must have already solved this much more simply...
are you using both the rear hangars? I wan only using one, and once I added the other, it really stiffened it up
Old Dec 18, 2008 | 03:47 PM
  #27
BlimeyCabrio's Avatar
BlimeyCabrio
Originally Posted by polepino
Yeah, I've been doing some research and it seemed to me more logical to free up the air flow closer to the engine than opening up the latter part of the exhaust. Do you think a header install would be as hard or harder than a cat back install for a DIY project? Or would it be better to just let the shop do it?
Yeah, it's not just *where* you "free up air flow" - but *how* you do it... adding a larger diameter (e.g. 2.5") exhaust doesn't do much if the primary constriction point is still the collector on the header. But the real *magic* of the RMW header are the equal-length primaries combined with the free-flow collector design - it radically changes the way the pulses of exhaust gas exit the header - in series instead of "crushed" together by the collector - and this is what gives is a combination of big sound and big added torque...
As for ease of install - I've dropped and installed exhausts several times - pretty easy. The Header isn't necessarily hard - but you really need a lift to do it - you need to remove bolts from the top side, then pull the header from the bottom - and reverse to install the new one. Or at least that's what my guru said the easiest way was...
Old Dec 18, 2008 | 04:16 PM
  #28
the platform's Avatar
the platform
I am pretty sure that they added more substantial hangers than the oem ones.I must admit that I did'nt look closely(huddled in the corner because it was near 32 degrees-frigid for Vegas)I told him that I wanted no more play/swing in the rear at the tips.The bad thing is ,that when you stiffen the hangers in rear(to eliminate play), you get new resonance in the rear to go with it.It's probably being absorbed into the chasis.Every time I get in the car,there are different sound combos at several rpm points.I guess it's the nature of the beast?More detective work.I wish our cars were easier to get under!Luckily the header is louder than the resonance!!! -love it.The performance benefits outweigh everything right now
ps-I have no rear seats,so it's even worse.I'll peek at it tomorrow.
Old Dec 18, 2008 | 04:27 PM
  #29
polepino's Avatar
polepino
...hmm.. yeah a shop install for the header seems best. How bout using car wheel ramps?
Old Dec 18, 2008 | 05:05 PM
  #30
AstroBlackS's Avatar
AstroBlackS
Platform - Glad to hear you are enjoying some sweet new mods! Not too many of us MCSa mega modders out there.
polepino - As for header install, it's totally easy. Did mine in my garage in about 2 hours. It seems more daunting than it is.
Here is a good how-to: http://webbmotorsports.com/index.php...w&id=8&catid=2
Oh, and as for loud exhausts...
http://www.youtube.com/watch?v=YmpvA...eature=channel
http://www.youtube.com/watch?v=P7dYs...eature=channel
I had to...
Old Dec 18, 2008 | 05:17 PM
  #31
the platform
Astro,
Yer still the king in my book!!
Are you still lovin' it??
I watch and listen to that one regularly.
I'm trying to find/borrow a vid cam so I can make you proud with my bombastic ,beastly notes!!
Old Dec 18, 2008 | 05:21 PM
  #32
AstroBlackS
Originally Posted by the platform
Astro,
Why thank you! and of course I'm still loving it!
Sweet dude, I eagerly await the video!
Heck, this summer, there is a possiblity that I may embark on an epic road trip cross country, so I may have to swing over to your neck of the woods!
Old Dec 18, 2008 | 05:27 PM
  #33
the platform
-you just say the word and we shall pillage the twisties.
It will be like DTM series came to town..
Old Dec 19, 2008 | 06:27 AM
  #34
AstroBlackS
Old Dec 19, 2008 | 08:19 AM
  #35
agranger's Avatar
agranger
That's always the trade off with exhaust hangers... You stiffen 'em by adding more of 'em, more material or a stiffer material. By nature, all of those things tie more of the exhaust vibration to the frame.
2 of the main rear exhaust hangers (well, 1 in my single-sided case) is a full-custom bracket with a metal frame that is enrobed in rubber... not gonna be an easy piece to replicate!
Old Dec 19, 2008 | 02:04 PM
  #36
onasled's Avatar
onasled
If anyone needs some of these, I got four brand new for sale. 2.5"
Old Dec 19, 2008 | 03:07 PM
  #37
the platform
..do these dampen resonance or are they simply clamps to fasten different pipe sections together...or am I geting colder?
Old Dec 19, 2008 | 03:25 PM
  #38
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
There V band clamps......
http://www.youtube.com/watch?v=yvIy_g5k8rI
If only you could hear the drone, well over 100 dbs
Old Dec 19, 2008 | 03:28 PM
  #39
onasled's Avatar
onasled
They are clamps. Three pieces. Weld the ends (samller pieces) to pipes and the center section clamps them. Perfect if you have parts that yu want to remove a lot. Say you want to remove your cat for a track day and replace with straight pipe. This makes it super fast and easy to do over and over again. Stanless
Old Dec 19, 2008 | 03:40 PM
  #40
the platform
-nice.
Old Dec 20, 2008 | 08:35 AM
  #41
ugliboi_87's Avatar
ugliboi_87
hey, i just want to know after you guy put the header on, when it's time to go smog check >>>> is the car going to pass the test or you have to put the stock back on? i'm planning on doing it, just need some more research before i do it.
thank youuuuuuuuuuuuu
Old Dec 20, 2008 | 10:27 AM
  #42
the platform
-that would be a question for them who have crossed such a bridge....at the moment I care not,because the sound and ummph is just to dandy!
***VIDEO/SOUND clips coming SUNDAY!
Old Dec 20, 2008 | 12:01 PM
  #43
user 7082082's Avatar
user 7082082
That's it. I am recording a couple sound clips today.
Old Dec 20, 2008 | 12:28 PM
  #44
Mini_Joe's Avatar
Mini_Joe
Yeah, me too. I won't promise anything broadcast quality... but it should be OK for it's purposes!
Old Dec 20, 2008 | 04:14 PM
  #45
K5Cruiser's Avatar
K5Cruiser
It passed the CA smog check/test in my car.
Old Dec 20, 2008 | 06:29 PM
  #46
BlimeyCabrio
Passed NC emissions test with no issues on mine.
Old Dec 20, 2008 | 06:47 PM
  #47
MINIotaple's Avatar
MINIotaple
Originally Posted by OXYBLUECOOP
Yep they are loud!
what does this car have on it?
Edit: Found my answer.
Engine/drivetrain=
05/06 transmission
RMW Cylinder Head
RMW Camshaft
RMW Street Header
RMW Rear Section
RMW Tuned
RMW 440 Injectors
Alta Pulley
Alta Cold Air intake
Lightened Flywheel
Luk Clutch
Old Dec 20, 2008 | 07:00 PM
  #48
Revolution Mini Works's Avatar
the car doesn't have resonators.... it's scary loud
Old Dec 21, 2008 | 01:21 AM
  #49
the platform
Hey Jan,
I took my MA for a ride yesterday(he has a r56 JCW).After snapping his neck back a few times and blasting his ears,He said that It was a monster.
Old Dec 21, 2008 | 05:55 AM
  #50
Hey Jan,
maybe you can steal his brakes now?
