Drivetrain Janspeed & Borla Cooper Combo on an S
Thought I'd post a vid of the Janspeed Manifold coupled to a Borla Cooper exhaust as I love the sound this combo makes on the S. (Excue the dirty car... too posh to wash :D)
Also below that is a 60-130 mph test run. Would love to hear what times others are getting.
Just to relay any fears, it was done in the UK and on a Network Rail access road which is a nice long stretch of private road next to a railway line. You just have to 'tip' the security guard ;-)
True. It's just that I've never been part of a locked thread before, and as stupid as it sounds, I want to be!
My little dose of LITHIUM
So, a quick review of the video shows the shift points as (approximately) -- I presume it's a 6-speed.
3rd-4th at 70mph
4-5 @ 95
5-6 @ 114
Is that right?
Sure sounds easy...
thanks for the video
3rd-4th at 70mph
4-5 @ 95
5-6 @ 114
Is that right?
Sure sounds easy...
3 to 4 @ 95
4 to 5 @ 114
Thanks, but I have three more questions: is your car an early 6-speed or a later model 6-speed? Would you be able to go much faster than 130 in 6th? If so, when would you change from 5th to 6th?
Of course all this is academic as there's no where around here that I could even go 130 let alone faster...
I'm intereated in the borla cooper mod you did. Was there any mods you had
to do to the exhaust to make it fit on your S. I like the look of the side
exhaust. If you could post a how to that would be great.
Thanks. Christian.
Thanks. Christian.
I will be doing a similar exhaust in the next couple weeks over my spring break from school, I am having a shop down in va fab up a single sided, side exit stainless exhaust with a magnaflow "race" muffler. The only parts i need to get on the side to get this to mount up is the rear lower black trim piece from a cooper ($50) and the two side reflector trim pieces that attach to it as those from a mcs do not fit to the rear trim of an mc... dont ask me why, this is just what i have read... i'll try to get a vid up in the exhaust thread in a few weeks when it is complete... should sound interesting running the meagan header with test pipe, and pretty much a flow through exhaust...
i know this is an older topic, but 2nd gear hits limiter at ~73-4 in my 03, and agreeing with bigshow, 6th is just for lowspeed cruising (50+), or if you threw an extra turbo/bigger supercharger on it and could go past 140.
http://www.minitorque.com/forum/vbga...p?do=view&id=2
Full mod list on post above, but in short:
RMW Head, Newman Cam, 17% Alta V2 Pulley, 440cc Injectors, 1320MINI Custom Tune, GRS Front Mount, JCW CAI with ITG Filter, RMW Oil Sump Baffle... the list goes on
Whp? tq?
