Drivetrain B&M shift kit install - HELP
Old Nov 14, 2008 | 02:41 PM
firenewt's Avatar
firenewt
I can't get the shift cable disconnected from the shifter. I've tried several methods, but no luck.
thanks,
Kevin
Old Nov 14, 2008 | 07:04 PM
Ryephile's Avatar
Ryephile
Use either needle nose pliers or interior panel trim removal tool....and put your back into it! The cables can be a real pain to remove, just be sure to pull/lever them off by the inner ball socket and not the outer ring.
Old Nov 16, 2008 | 02:46 PM
firenewt's Avatar
firenewt
Got it! Ended up using a small crowbar. Fit the inside of housing so had good leverage. Give it a sharp rap and it popped off.
Kevin
W0TM8
Dec 19, 2019 07:50 AM
adrchn
Aug 13, 2019 02:11 AM
Toolman
Jan 20, 2016 06:50 AM
