Drivetrain How do you set the tension tab
Old Nov 12, 2008 | 07:04 AM
  #26
Mike S's Avatar
Mike S
Originally Posted by DrPhilGandini
Id give the 1370 a try, sounds very close. The others might be too short.
I got a 1365 today! The gates 1370 is only coming in a couple days, probably next week :( Has to be shipped from the supplier which is 1000 miles away.
Can I give this a try?
Old Nov 12, 2008 | 07:48 AM
  #27
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
So long as you can get it on, and the tensioner is not totally compressed, go for it! It's not a big job, so give it a try.
good luck
Old Nov 12, 2008 | 08:06 AM
  #28
Mike S's Avatar
Mike S
good luck
Thanks Doc!
Old Nov 17, 2008 | 01:12 PM
  #29
bomboasy's Avatar
bomboasy
What belt to use
OK, I need some help, please. I have an Alta -15% pulley and a +3% Flywheel. To top it off I also have a +5%Altanator to keep the alternator alive. The question is what size of belt should I use?
Gatorback
NAPA
Gates
other
Thanks ahead.
Bomboasy
PS. I did some damage to the passenger plastic runner under the door, outside of the car and the rear right plastic jack placement point. Name a place where I can get parts for reasonable price. Thanks.
Old Nov 19, 2008 | 03:28 PM
  #30
bomboasy's Avatar
bomboasy
hello, any one with some help?
Thanks.
Bomboasy
Old Nov 25, 2008 | 07:57 PM
  #31
jm6001's Avatar
jm6001
I have had tensioner issues for the past 3 years of owning my Cooper S. I have replaced my tensioner 3 times now and MULTIPLE belts and have yet to correct the issue. I had installed the new tensioner about 3 months ago with a new belt for the 17% Alta pulley I have (I checked all the part numbers and I had definaitly bought the right belt every single time) I even tried to get a size smaller then the ones that were suggested to use and it would not fit, it was way to tight.. Now I checked my tensioner 2 days ago and you know the small tab at top of the tensioner thats twisted (ie. the end of the peice of metal with the "holes" in it) is completely missing aka. BROKEN OFF! This car honestly is just ridiculous sometimes and I just cant take it anymore, lets just say Iam sad to see it go in 2010 but Iam damn happy that I wont have to pay for fixing it every 2 months. IF ANYONE KNOWS WHAT IS WRONG WITH MY CAR PLEASE TELL ME BECAUSE I CANNOT AFFORD MORE TENSIONERS AND BELTS AT 230 a peice and 50 a peice.. PLUS INSTALLATION!!!!!!!!
Jm
timwhayden
Aug 24, 2015 08:42 PM
O4mcs
Aug 10, 2015 10:22 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
Aug 7, 2015 09:51 AM
