Drivetrain Alta Boost Tubes Causing Check Engine Light
Old Oct 10, 2008 | 08:20 PM
sk8erguyzach's Avatar
sk8erguyzach
ok finally got the cold side on after destroying my hands and refitting the pipe so it is on correctly without leaking but during my second check the check engine light came on and is still on after properly fitting it i cant hear leaks any more even under heavy acceleration but the light is worring me.... i have not installed the hot side from the turbo to the intercooler yet anyone think that might be the problem? not enought air on the hot side too much on the cold?
Old Oct 10, 2008 | 08:29 PM
Sketch's Avatar
Sketch
There could be a problem with the amount of air being moved through the upgraded tubes. That has happaned before with other NAM people. The mini would recognize this as a problem and the CEL goes on. If I were you, talk to Alta. Surely they would help you.
Old Oct 10, 2008 | 08:37 PM
sk8erguyzach
no need
after afew on/off then a drive to the store it went off guess it just need time to reset wish me luck on the hot side tube tomarrow
Old Oct 10, 2008 | 09:28 PM
MiniManiac74's Avatar
MiniManiac74
The hot side is easy compared to the cold side. Post up if you have any more CELs because I haven't had that experience with my tube upgrades. Good luck
Old Oct 11, 2008 | 05:43 AM
slinger688's Avatar
slinger688
My cold side caused a CEL as well. It started two days after putting it on. Decided to take it off and put on the OEM. Brought it back to the dealer with the OEM tube on and he could not find anything wrong with it.
Old Oct 11, 2008 | 09:23 AM
JAceMin's Avatar
JAceMin
First you guys should post this stuff in the mods section.
that aside, two things;
- Are you positive you have no leaks? did you disconnect the battery terminal prior to working on the car, did you double check the fitment after a test drive to ensure everything is still tight and mounted right?
-Did you call Alta, they are willing to help.
Old Oct 11, 2008 | 09:49 AM
slinger688's Avatar
slinger688
Thanks Jacemin,
I will reinstall at a later time. It is much easier the second time around. Something may have come off/loosen after a couple of days but I am now back on OEM. I am not sure of any HP/Torque gain I got from just the cold side. Going to the mod section ...
Old Oct 11, 2008 | 03:51 PM
sk8erguyzach
finally got the hot side pipe in. It was slot easier than the cold side. Only troubles was getting the PITA. Torx screw and getting the intercooler side on all the way the intercooler side popped off right as I took off from the drive way. Fixed it easily. And love the sound.
Old Oct 11, 2008 | 04:43 PM
Sketch's Avatar
Sketch
So in terms of sound it releases more exhaust noise, or it releases the BOV sound more? Just curious, as I want to do this mod eventually...
Congrats on your install btw, happy it worked out for you!
Old Oct 11, 2008 | 08:37 PM
sk8erguyzach
it makes the exhaust a lil more deeper but not much but you definatly hear the turbo spool alot more than with just an intake and it definitly a quicker spool and better high end torque
id say get it but look into exhaust depots theres is metal and you can get it with an hks bov and you can order it through them and have them put on the bov
overall toughness on installing is a 3 out of 5 alta makes it seem easier than it really is the steps of installing are a peice of cake its just the removing the oem and putting on altas thats a PITA
hope i helped add me on your buddy list and i can give you pointers and tips to make the install easier when you decide to do it
Old Oct 12, 2008 | 03:25 AM
Sketch's Avatar
Sketch
Added! And I will definitely send a PM when the time comes. The main thing that does it for me is the sound. That plus an ALTA CAI would do it me thinks...
Old Oct 12, 2008 | 01:45 PM
sk8erguyzach
definatly you will love the sound i will make a vid and post it so youll have an idea of how awsome it sounds
Old Oct 12, 2008 | 02:12 PM
Sketch's Avatar
Sketch
Great! Cant Wait!
Old Oct 15, 2008 | 02:55 AM
sk8erguyzach
thought id send you a pick off my hand after installing altas cold side boost tube its a pretty tough spot to manuever in so your bound to end up with nics and scratches i will have the video off the tubes this weekend ive been supur busy
Old Oct 15, 2008 | 04:06 AM
Krut's Avatar
Krut
A good mod always draws blood!
Old Oct 15, 2008 | 07:15 AM
JC Scooper's Avatar
JC Scooper
Your hand is like that of a "fair maiden" compared to mine after that install! But all is well now and I have never had any leaks or CEL coming on in well over a month. Presently waiting for my red CAI to finish up under the hood.
Old Oct 15, 2008 | 08:58 AM
MiniManiac74
LOL. My hands were also much worse. I had some pretty big gashes on my left hand that stayed with me for a while.
Old Oct 15, 2008 | 10:32 AM
Exhaust Depot's Avatar
Exhaust Depot
From: Orlando, my house is in fortlauderdale and im originally from da bronx
I had a CEL come on also (with my setup). Its due to a leak in the hose somewhere. You have to check that the clamp is on good or it will leak. If you dont know what to listen for it will be hard to hear the leak unless its really a big one.
What I did to find mine was to lift the car off the ground with the lift. I turned traction control off then had my cusotmer get on the gas. I found it right away when the car went into boost. YOu cant really find it just reving it.
Old Oct 15, 2008 | 10:51 AM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Hey folks just a couple points to ponder:
sk8erguyzach:
1) The tubes can't cause a CEL if installed properly.
2) I know we spoke via PM, and you mentioned a connection being left loose on the T/B.
3) Glad you got that connection corrected.
4) From our conversation the ECU must have worked to correct the CEL.
PLEASE let me know if I can ever help you or any other members in the group!
THANK YOU ALL!
Old Oct 15, 2008 | 11:00 AM
ADAMSALTAMINI
FYI: WEAR GLOVES
This part is a bugga to install without bleeding with bare hands. Having been a wrench for going on 20 years now, I can't stress enough the importance of a good pair of gloves when working on cars.
They keep you fingers clean (the significant other will love that), they help prevent bleeding, burns, improve leverage etc etc.
I use two pairs of gloves. One inner is a just a rubber or latex, then the outer is more of a mechanics type glove. Then if I need to remove the outers (too big or need to do detail work) then I am still covered on the inside.
Some of the best $20 you can spend in your tool kit!
Thanks again folks!
Old Oct 30, 2008 | 08:03 AM
D-Unit's Avatar
D-Unit
Now would be a good time for you guys on the fence. The boooooost tubes are on sale for $199.99. Should be getting mine this week or early next week. Ordered them online sunday.
Old Oct 31, 2008 | 08:47 AM
ADAMSALTAMINI
Thank you! Let us know what cha think!
Old Nov 5, 2008 | 07:50 AM
D-Unit's Avatar
D-Unit
Got em last night! I'm gonna try to install them this weekend. Then I have Phil Wicks on Monday, which should be a good test.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
