Drivetrain Is this normal results for 2003 Cooper S JCW 210hp dyno?
Old Sep 7, 2008 | 08:36 PM
  #51
D-MAN's Avatar
D-MAN
Originally Posted by Mike S
Thanks //MZero! I'll have it checked.
In the meantime here are the dyno sheets are promised.
First one is of my Mini Cooper S JCW. Does everything look normal here? No clutch slippage etc?
My friend's Fiesta ST that was dyno'd right before me. Car is stock except for aftermarket cams and CAI.
Considering a Fiesta ST puts out around 125kw and the JCW 150kW looks like the dyno reads low...
Old Sep 7, 2008 | 10:49 PM
  #52
BlueMax's Avatar
BlueMax
Mike - what gear was used (both Mini & Fiesta?) For your car the graph shows 173 km/h and 425m vs Fiesta 133 km/h vs 225m - what is the significance of that? Also remember that dyno results can be like stats, it can prove (or not prove) anything. The fact that you physically out-accelarate the Fiesta comfortably (in a heavier car) should show that the dyno results may be questionable. What did Mr Turbo (dyno place) have to say about the results, conversion factors etc? Did they test any other MCS's or JCW's - would be interesting to see more data. Cheers
Old Sep 8, 2008 | 01:00 AM
  #53
Mike S's Avatar
Mike S
Originally Posted by billzcat1
That looks like a normal dyno graph with skewed numbers to me. Carry on with your search. What have you actually checked/replaced at this point?
I haven't replaced anything yet. That same friend of mine are going to another dyno to get a "2nd opinion". We will see if my results are proportionate to the previous dyno and then I will know if something must be wrong with my car.
  #54
Mike S's Avatar
Mike S
That's exactly what doesn't make sense to me. That's why I'm suspecting something is not running 100% with my car.
Old Sep 8, 2008 | 01:03 AM
  #55
Mike S's Avatar
Mike S
Hi BMax, my car was running in 4th gear. The Fiesta was running in 3rd gear. I didn't really question him much about it, although I could give them a call today and see if they have or have not dyno'd other Cooper S' - my results are what a standard Cooper S should be dyno'ing not a JCW.
I got your PM and will give you a ring later today
Old Sep 8, 2008 | 12:34 PM
  #56
billzcat1's Avatar
billzcat1
Actually thats lower than a Cooper S should dyno as well. There doesn't seem to be a problem with the dyno except it might read a touch low, but that doesn't explain the missing 50 whp.
I think re-dynoing is a waste of time and money. Start focusing on the problem not the symptoms! Do yourself a favor - do an MCS tune up - Belt, Intercooler Boots, and possibly Spark Plugs. You'll spend less than $100 and likely solve the problem completely.
Old Sep 8, 2008 | 01:36 PM
  #57
Mike S's Avatar
Mike S
Ouch, talk about adding salt to the wound
I'll give that a try - hopefully my problems will be solved then!
Old Sep 8, 2008 | 04:27 PM
  #58
//MZero's Avatar
//MZero
Mike, does something really feel wrong with the car? If not I don't know why you are trying to fix something that may not be broken. Do ONE thing...call the dyno operator and ask if the numbers are corrected or uncorrected in relation to atmospheric pressure.
If the numbers are uncorrected then YOUR CAR IS OKAY! Continue on with modding, change your belt when you put a new pulley on, have the plugs "looked at" when they pull them out for the compression test...you probably don't need new ones, nor will they help. Visually inspect your intercooler boots...do they look worn and old, or do they look like they might be ok?
Honestly there really is no reason to spend money that you don't need to. Re-dynoing may be a waste of money, or it may not. If the numbers at the new dyno are corrected and the ones at the first dyno were uncorrected, then you will finally see that you car is actually making decent power...Some people put too much weight in dyno numbers, sure if your car is only making 130whp corrected something is seriously wrong and must be looked at. But if your car is making 165whp corrected then I wouldn't be concerned.
Old Sep 8, 2008 | 04:38 PM
  #59
billzcat1's Avatar
billzcat1
Like I said - when my belt was slipping I had no idea. The car felt fine, but in anticipation of an RMW tune I put on a new shorter belt and the car was immediately much faster. I had no clue it could make such a huge difference.
Old Sep 8, 2008 | 04:44 PM
  #60
//MZero's Avatar
//MZero
^ If he wasn't on the stock pulley I could see that being a real problem. But stock JCW pulley with stock JCW belt...and the fact that it appears he is making ~ 160whp
Now if he had a 15% pulley and stock belt, or even JCW belt, then I would look into that. But this is not the case
Old Sep 8, 2008 | 05:11 PM
  #61
Mike S's Avatar
Mike S
Hi M,
I understand where you are coming from and it would not worry me so much if my friend hadn't tagged along. It doesn't make sense to me that his car wasn't effected by altitude as badily as my car. Surely the loss in power to be proportionate?
Old Sep 8, 2008 | 05:13 PM
  #62
Mike S's Avatar
Mike S
I really really hope that is the case. I will inspect my intercooler boots etc. tomorrow. They are still the OEM original since new ones and the car is now 5 years old with 37,000 miles on.
Old Sep 8, 2008 | 05:45 PM
  #63
//MZero's Avatar
//MZero
Hi M,
125kW*.85 for drivetrain loss is 106.25kW*.81 for altitude loss = 86kW
150kW*.85 for drivetrain loss is 127.5kW* .89 for altitude loss = 113kW
So ok...yea, your car is a lower on power then, by about 17kW or 24hp...even if the numbers are uncorrected. But thats a lot better then 50hp off.
Another thing I forgot to mention, you car should actually loose less hp with altitude then your friends since your engine is supercharged and his is naturally aspirated. The equation is still very simple. If the correction percent is 81% multiply 14.7 * .81 this gets 11.9. This means that the outside air pressure is 11.9psi (standard sea level is 14.7) now add your boost pressure to 11.9 I used 13psi since you have a JCW and that is relatively close. Now 11.9 + 13.0 = 24.9 this is total pressure in you manifold, compare that to sea level 14.7 + 13.0 = 27.7 so at sea level you would have 27.7psi in the manifold 27.7/24.9 = .89 89% is your correction for your force induced vehicle that day. Just explaining how I came up with the approximation numbers.
Sorry you car IS running poorly
Old Sep 8, 2008 | 08:28 PM
  #64
billzcat1's Avatar
billzcat1
Well 96 wkW = 128 whp and a 210hp car should dyno around 178.5 whp (15% drivetrain loss, which has actually been proving too high for most tranverse mount manual-transmission applications).
At 4300 feet, the air is approximately 85% as dense as at sea level.
Don't forget with your correction factors that the boost provided by the supercharger is actually a pressure ratio based on ambient pressure, not a fixed pressure increase. A turbo with a wastegate will indeed provide a fixed pressure increase (up until the turbo hits the surge limit) but a fixed-displacement blower will not. If ambient pressure is 15% lower than at sea level, so will the manifold pressure post-supercharger.
So if we assume 15% lower mass of air consumed, the car should be around 152 whp or 114 wkW
Old Sep 9, 2008 | 03:20 AM
  #65
Mike S's Avatar
Mike S
Very interesting with the in depth explanations, thanks for taking the time in working all that out
The last sentence is what I wanted to hear, just needed to confirm if there was in fact something wrong with my car! :(
Old Sep 9, 2008 | 03:22 AM
  #66
Mike S's Avatar
Mike S
At least I know more or less what I'm missing. Need to find 20wkw/30whp from some where!
Old Sep 9, 2008 | 07:55 AM
  #67
//MZero's Avatar
//MZero
It gets you in the ballpark, figures aren't exact anyway, but rather a good idea of where you should be. I ended at 113kw you ended at 114...close enough. I started at 150kw (205hp) you started at 210hp
Old Sep 9, 2008 | 08:10 AM
  #68
muladesigns1's Avatar
muladesigns1
I'm thinking that the Dyno wasnt calibrated properly.
I would have them do it again, watching over there shoulder to make sure they actually know what there doing.
I just cant see your numbers being that low with all the mods you have.
Old Sep 9, 2008 | 08:53 AM
  #69
Mike S's Avatar
Mike S
I'm going to rather wait until all my new mods at been installed before I get dyno'd again. At least that rules out any possibility of the old parts causing the loss in power.
I also checked the intercooler boots, the seem to be fine. I installed my M7 OCC which arrived today. Here are some pics.
Old Sep 9, 2008 | 10:33 AM
  #70
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Mike S: will you have to remove the OCC to change the oil filter?
Old Sep 9, 2008 | 01:51 PM
  #71
Mike S's Avatar
Mike S
I have no clue where the oil filter is and it will only get changed once year as I don't drive the car all that much, so even if it is just beneath/next to the OCC I don't mind.
Also that is where M7's instruction recommends placing it. I also couldn't find another area with enough space. This was more of a PITA to install than I originally thought too, one of the torx screw heads fell into the engine bay somewhere and I can't find or seem to shake it out. I hope it will fall out on it's own some time. Good fun none the less, I learned something new about DIY.
Old Sep 10, 2008 | 10:23 AM
  #72
Ralph@Helix's Avatar
Ralph@Helix
Mike,
the 2003-2004 jcws were rated less than 210hp
Also does the dyno shop you went to have other dynosheets of mini's for better caparisons?
Old Sep 10, 2008 | 10:38 AM
  #73
Mike S's Avatar
Mike S
Originally Posted by Ralph@Helix
Mike,
Hi Ralph - I know there were different version of the JCW kit. Mine is the latest/last one BMW brought out for the R53's. I only got the kit installed in 2005. I haven't phoned the dyno yet, I'll find out though.
Old Sep 25, 2008 | 06:04 AM
  #74
Mike S's Avatar
Mike S
I just finished installing my boost gauge. It says my max boost is 0.6 bar (8.7psi) - what is the standard boost supposed to be on a JCW?
I think this is where my problem maybe... slipping belt?
Old Sep 25, 2008 | 07:29 AM
  #75
//MZero's Avatar
//MZero
^ likely, I think JCW's are around 12-13 psi
edit* although at altitude you might not produce that...on a hot day up where you are I assume it could be as low as 10psi but shouldn't be lower then that
