Drivetrain Smoking
Old Aug 9, 2008 | 02:12 PM
MinS's Avatar
MinS
Smoking
Hi, so I just installed my 15% pulley with a new belt, after driving it, letting it sit then driving it again, the car smokes from the pulley section, like something is wrong with the tensioner. Why I think its the tensioner is because it is showing half of the hole on the tensioner and also when it stops vibrating/shaking, the rattle and smoking stops
Old Aug 9, 2008 | 02:19 PM
kapps's Avatar
kapps
Tensioners do go so that could be the problem. Are you sure it isn't the penetrating lube you sprayed on the shaft the get the pulley off?
Old Aug 9, 2008 | 02:33 PM
MinS's Avatar
MinS
ya, its not that because it smoked pretty bad and smelled like burning rubber, also the belt has slipped to the edge of the supercharger pulley, like how the pulley is 5 teeth, like the edge of the belt is off it. So im thinking its the tensioner it became loose and the belt slipped a bit
Old Aug 9, 2008 | 03:05 PM
custard's Avatar
custard
It could be the tensioner, but i'd suspect that it's more likey to do with the problems you had installing the pulley.
Originally Posted by MinS
have a feeling a ruined the supercharger... I used the pulley puller 3 jaw type from sears, started getting harder to get tighter and tighter, then boom, something popped out, and then i saw the hole shaft come out a bit :( really bad week, the shaft is now really hard to spin. Don't know what to do now
https://www.northamericanmotoring.co...d.php?t=150304
I'd serously consider calling in a professional at this point, seems like you're having a lot of bad luck with that pulley install. Best get it checked out by a pro before anything else goes wrong.
Old Aug 9, 2008 | 03:13 PM
MinS's Avatar
MinS
after reading more, the rattleing and everything goes away once the tensioner stops vibrating, so I doubt the supercharger or the install of the pulley is bad because when it is running perfect, the pulley doesnt move or anything, the belt turns perfectly straight. It just feels like the tensioner is bad because when I rev it to about 1500 and let go, i could hear a rattle meaning the tensioner rattling, The noise is coming from around there too not near the supercharger
Old Aug 9, 2008 | 06:03 PM
MinS's Avatar
MinS
just looked at the car more, the crank pulley appears to look bent, keeps shaking left and right. I remember my idiot friend started the engine, while the engine was titled so the crank was rubbing on the chassis. :( is it possible I bent the shaft on the crank pulley?!?!
Old Aug 9, 2008 | 07:17 PM
kapps's Avatar
kapps
If the "shaft" on the crank pulley is bent, you bent the crank (very very bad). Hopefully, it's just the crank pulley that is bad. Those can be had for about the price of a SC pulley.
Old Aug 9, 2008 | 11:35 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
...my idiot friend started the engine, while the engine was titled so the crank was rubbing on the chassis...
Why did he do that!?
Old Aug 10, 2008 | 04:12 AM
MinS's Avatar
MinS
IDK why in the hell he did it but he did. And also there is a HUGE dent on the crank pulley, so Im assuming the crank isnt bent, just the pulley is bent because sometimes it will spin and not make the noise, so I guess the crank pulley is out of balance and also bent where the bolt goes so it wobbles.
Old Aug 10, 2008 | 10:28 AM
british RACING green's Avatar
does not sound like fun.
keep us posted on whats happened and what you find out
good luck, hope what evers wrong can be fixed easily without too much expense
Old Aug 10, 2008 | 10:41 AM
Nitrominis's Avatar
Nitrominis
You can't bend the crank..
But what you can do is mess the balancer up, which is most likely what happen. If it is moving as you described its time to replace it before it grenades on you.
Old Aug 10, 2008 | 02:43 PM
MinS's Avatar
MinS
so buying a new crank pulley would fix it? the vibration damper is inside the pulley right? or is it another piece?
Old Aug 10, 2008 | 02:55 PM
Nitrominis's Avatar
Nitrominis
balancer is the crank pulley?!?!!
The terminology is getting garbled. Your buddy toasted your Balancer/ Vibration Damper on the crankshaft. Get another one (under many names: harmonic balancer, damper, or Vibration Damper) before you do really bad damage to the engine or other parts of the Mini.
BMW/Mini calls them Vibration Damper
Old Aug 10, 2008 | 03:10 PM
MinS's Avatar
MinS
i just did some research, just want to make sure this is correct, so the vibration damper is the crank pulley?
Old Aug 10, 2008 | 03:15 PM
Nitrominis's Avatar
Nitrominis
It difficult at times to remember all the slang term for all the parts.
Yes the vibration Damper is on the crank (crank pulley) and the poly (ribbed or drive belt) belt goes around it.
Hey I get people that ask what my license plate means all the time ??
And most drive MINI's
Old Aug 10, 2008 | 03:20 PM
MinS's Avatar
MinS
Haha, ya i am not use to the terms people use for things, i like to use the plain old fashion words that are easy to remember haha.
But from reading from your plate I assume your MC has a blown engine right.... nice plate tho btw
Old Aug 10, 2008 | 04:12 PM
Nitrominis's Avatar
Nitrominis
The old HOT RODs with Super Chargers the slang term for the Super Charger was BLOWER
So like your MCS you also have a BLOWN Engine.
RobbyD
Jan 29, 2019 01:22 PM
pfcmooney
Jun 15, 2016 07:22 PM
embiggenedmini
Oct 15, 2015 12:36 PM
micromini234
Sep 30, 2015 07:36 PM
Jolio
Factory JCW Talk (2009+)
Sep 17, 2015 09:23 PM
