Drivetrain Boost/Vacuum readings...
Old Jul 8, 2008 | 02:38 PM
MSFITOY's Avatar
MSFITOY
As the title suggests, I would like some input from any of you who have monitored your boost and vacuum reading at various stages of the motor's activity.
Specifically:
1-maximum boost (please include pulley %) with rpm,
2-maximum coast down vacuum on level ground from highway speed (60-80mph),
3-and finally, idle vacuum.
Important caveat, please do not use analogue gauge readings as they are prone to parallax and are just generally not very accurate. If you have collected these data with some type of high resolution digital boost/vacuum gauge or reading converted from OBD2 readers, they would be greatly appreciated!
Old Jul 8, 2008 | 07:25 PM
kapps's Avatar
kapps
(edit) oops, didn't read your no analog statement...
Old Jul 8, 2008 | 08:24 PM
big howe's Avatar
big howe
I just deleted a whole bunch of just driving around data runs, so I'll have to go from memory. I could have better numbers tomorrow. I think the DashDyno reads in PSI positive and negative.
Max boost about 16.5 psi at 7500 with 17% pulley
Idle is about -6.5 to -8psi
Coast down, never looked that close, but I remember around -11psi
Again, this is foggy memory, I can get more tomorrow unless you really want it tonight, then I could go for a quick drive.
Old Jul 8, 2008 | 10:56 PM
HighLife4136's Avatar
HighLife4136
Phoenix, AZ ~1100 feet above sea level
15% pulley, Alta V1 TMIC, 7000 RPM
Max Boost = 14.3 psi
Max coast = -11.7
Idle = -6 ac on and -7.7 ac off
These are off the top of my beer coated memory from a Scanguage II using an Xguage to calculate boost instead of MAP.
Last edited by HighLife4136; Jul 9, 2008 at 07:05 PM. Reason: Removed beer coating from memory...
Old Jul 9, 2008 | 01:22 AM
D-MAN's Avatar
D-MAN
1. 15.6 psi >7,000 rpm (16%+2%)
2. anywhere from -7 to -10 ish
3. -8 ish
Scanguage II
Old Jul 9, 2008 | 05:41 AM
MSFITOY's Avatar
MSFITOY
Wow...we're kinda all over the map a bit...I suspect that I have either/both boost/vacuum leak somewhere because of my numbers...
1-14.5psi (low) @7000rpm, 15+2%, DFIC (cause slight pressure drop?)
2-coast down neg 11.5-neg 12.3
3-idle neg 5.5-neg 6.2
Old Jul 9, 2008 | 11:14 AM
carbonized's Avatar
carbonized
My gauge is analog so I can't play
Old Jul 9, 2008 | 11:46 AM
fullcollapse40's Avatar
fullcollapse40
you might also want to consider what modifications have been done, such as cam, big valve cylinder head, catless exhaust when trying to compare readings from one car to another.
Old Jul 9, 2008 | 02:07 PM
MSFITOY's Avatar
MSFITOY
I'm happy just to get the few feedbacks that I can get...considering all the "mad modders" out there, I figured I'd get more samples from Minis with the right instrumentation...
Old Jul 9, 2008 | 05:06 PM
works4me's Avatar
works4me
Unfortunately I didn't have a digital boost input till right before I added the Turbo, so most of my logs wouldn't be helpful. I do know that on dyno runs I used to get 17psi max with a 15%+2% combo.
I came across this test run (below) which I think is when the car was in an "intermediate" stage (i.e. no Turbo, 0% pulley + 2% Crank, modified internals). Yellow is boost, Purple is GPS-measured speed, Red is RPMs.
I can keep digging around if you think it would be useful...
Old Jul 9, 2008 | 05:23 PM
gnatster's Avatar
gnatster
Well I tried and proceeded to screw up the Auterra Dyno-Scan install and have lost the key. Spend the better part of the afternoon looking for the CC receipt to request a new key. And the G2X...arghhh lets not go there. Still working with them to get it right. You'd think after a year they would stop repairing the unit and send me a new one.
Old Jul 9, 2008 | 05:27 PM
big howe's Avatar
big howe
Why did you go and screw it up? Nothing better to do?
MSFITOY's Avatar
MSFITOY
LOL...I knew you had to have been busy somewhere in the background...
Old Jul 9, 2008 | 05:31 PM
D-MAN's Avatar
D-MAN
I am putting in my DFIC 2 on the weekend so I will let you know if there is a noticable drop in any of the readings
Old Jul 9, 2008 | 05:32 PM
MSFITOY's Avatar
MSFITOY
Your help is always appreciated...
Old Jul 9, 2008 | 07:06 PM
HighLife4136
Edited my first post.
Old Jul 9, 2008 | 07:09 PM
MSFITOY's Avatar
MSFITOY
Old Jul 9, 2008 | 07:15 PM
HighLife4136
I edited post #4. My memory was a little askew and after driving around today, I got some accurate readings...
Old Jul 9, 2008 | 07:26 PM
gnatster's Avatar
gnatster
Needed memory space on the phone so uninstalled a bunch of stuff I never use. Figured I'd do a clean Dyno_Scan install too since I had all the files for like every Marque. Not to often I need to read a Kia codes. Auterra already sent me a new key...quick turnaround. I'm impressed.
Old Jul 9, 2008 | 07:45 PM
big howe's Avatar
big howe
I'm just giving you a hard time. It's like your sig. The best of intentions and then it goes downhill quick.
Old Jul 9, 2008 | 07:56 PM
kapps's Avatar
kapps
works4me, the label on your graph for the boost/vac is in psi. Is the vacuum in psi or in Hg? I'm leaning towards in Hg because you're seeing over 20 psi of vacuum. That is equal to 40 in Hg and a perfect vacuum is only around 30 in Hg. Also, almost 20 psi with only a 2% crank pulley
For the rest of you, are you giving vacuum readings in in Hg or psi? I'm guessing psi since you are all in the 10-12 range for deceleration. I can't play in this thread either because I only have an analog gauge but I get comparable readings at idle and max boost but I don't get quite as much vacuum as you guys on deceleration.
Old Jul 9, 2008 | 07:58 PM
gnatster's Avatar
gnatster
Anyone else using the Auterra Dyno-Scan for Palm....I have some questions but we should move that elsewhere.
Old Jul 9, 2008 | 09:13 PM
HighLife4136
psi
Old Jul 9, 2008 | 09:30 PM
big howe's Avatar
big howe
Your question may be Palm specific, if not I have the Dashdyno and Dyno-scan for the laptop.
Old Jul 10, 2008 | 04:14 AM
MSFITOY's Avatar
MSFITOY
I'm assuming my gauge stays in one scale all the time...so it's psi...
