Drivetrain Pinging under load...Knock sensor, High compression?
Old Jul 8, 2008 | 03:35 PM
  #26
Longboard110's Avatar
Longboard110
Originally Posted by COOUUPER S
I had Jan tune my car as well and put alot of time into it. At the end I still thought it had some pinging at WOT and had Jan work with the ecu a bit more. It turned out that this pinging, ticking, and knocking sound was coming from my front driver side axel. Are you sure the pinging sound you are hearing is from the upper middle dash or somewhere around the lower driver or passenger area ?
What was wrong with the axle and what did you do for a fix?
Old Jul 8, 2008 | 03:53 PM
  #27
user 7082082's Avatar
user 7082082
I have not done anything yet. The noise is coming from the axle/trans area. It sounds just like pinging to me but not from where it's suppose to be coming from. I have to check it out and ensure myself that it's a drivetrain noise.
Old Jul 9, 2008 | 07:23 PM
  #28
enologuy's Avatar
enologuy
Post Jan Visit Update...
OK all you pingophobes or pingophiles, whichever it may be, I saw Jan today and the problem has been cleared up!
Since the car was not running properly during the first tune, I replaced the plug wires, cleaned the MAFS, ran Seafoam through the gas tank, then ran half a can of Seafoam through the exit side of the intercooler. After all this, we had pinging when I stomped the pedal in second and third gear from 2800 to 3200 rpm. After multiple runs, and checking IATs, the pinging subsided to a couple of ticks when IATs were at 150 or just below. From 140 down, the pinging stopped. The pinging only happened when I floored it AT 2800 to 3200 rpm. If I floored it at, say, 2500 rpm, no pinging through the rpm range. Now, the car pulls better than it ever has, goes through the gears quicker and is a joy to drive once again. There were a number of time where I chirpped second gear without really trying!
My hats off the Jan for taking the time to dial my Frankenstein beast in. I suspect there will be some wine coming your way. For as we all know, when the wife is happy......... Feliz Noche!
Old Jul 9, 2008 | 07:46 PM
  #29
ED955S's Avatar
ED955S
That's good to know.
Old Jul 9, 2008 | 08:11 PM
  #30
Revolution Mini Works's Avatar
thanks Doug,
had a great time hanging out , the wife will surely like the vino
Old Jul 9, 2008 | 08:29 PM
  #31
Intense's Avatar
Intense
252whp 200trq RMW style
Originally Posted by Revolution Mini Works
thanks Doug,
What exactly was the problem Jan? Was it the plug wires carbon etc? Or were you able to just fine tune the pinging out?
Or a combination of everything? As you can imagine I'm very interested in the magic worked here
Old Jul 9, 2008 | 08:41 PM
  #32
it was a laundry list
call me tomorrow to discuss your car
Old Jul 9, 2008 | 09:02 PM
  #33
Intense's Avatar
Intense
Will do! Thanks
Old Jul 23, 2008 | 04:19 PM
  #34
roggenmini's Avatar
roggenmini
I seem to be having a similar problem with pinging. I have yet to tune but it is on my list. Guess I will have to do it sooner than later.
Old Sep 6, 2008 | 01:45 PM
  #35
Longboard110
Just wondering if anything ever came of this?
Old Sep 6, 2008 | 05:08 PM
  #36
it was an axle
Old Sep 6, 2008 | 05:11 PM
  #37
Longboard110
it was an axle
just curious what happened to it and what was the cause?
Old Sep 6, 2008 | 05:13 PM
  #38
you will have to ask Art, once we isolated it to the axle he left for work
Old Sep 6, 2008 | 05:15 PM
  #39
Longboard110
10-4 thanks, ill wait to see what he posts up about it. I have a similar noise coming from lower driver side dash, so im curious
TREX
Nov 2, 2019 07:31 PM
Aug 25, 2015 09:18 AM
kpl
Aug 11, 2015 04:52 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
