Drivetrain Cat back alone or get header?
Old Jun 14, 2008 | 09:44 PM
Bang110's Avatar
Bang110
I have been looking around and I think I want to get the IE cat back exhaust. Good price, good reviews and it sounds good. Not too loud and doesn't sound like a cheap ghetto honda.. While I am ordering everything I was also thinking about getting a Megan Header also. I wanted to get your thoughts on this combo. Will the header make the car too loud? It's my everyday car and while I dont mind some noise, I dont want it to be annoying on longer drives. I have an Alta intake and will also be getting a SC pulley.
Old Jun 15, 2008 | 01:34 PM
Bang110's Avatar
Bang110
Old Jun 15, 2008 | 03:48 PM
tropicatango's Avatar
tropicatango
up i want to know too
Old Jun 15, 2008 | 05:33 PM
silversmoke06's Avatar
silversmoke06
The header wont make the car a whole lot louder.
usualy its the mufflers that do that.
the stock manifold is thin tubing just like a header would be. so do your self the favor buy the header and enjoy the better flatter Tq curve.
but Like the addage gose. Wrap your whacker before you attack her.
for the header heat wrap helps alot.
Old Jun 15, 2008 | 06:23 PM
Bang110's Avatar
Bang110
I thought I read in a car magazing once that wraping the header is good but it will also cause the header to rust out or not last as long. I was thinking about getting it ceramic coated.
Old Jun 16, 2008 | 06:30 AM
MINIFVR's Avatar
MINIFVR
^^^Yeah its life will be reduced somewhat.
Old Jun 16, 2008 | 08:46 AM
Bang110's Avatar
Bang110
So in that case would it be better to just get a header and have it ceramic coated?
Old Jun 16, 2008 | 09:17 AM
OldRick's Avatar
OldRick
Replacing the header and cat also makes you a Federal felon, and carries a substantial fine and jail time if you were ever prosecuted.
Seems like a reasonable trade-off for 6-7HP...
Old Jun 16, 2008 | 09:59 AM
checkmate2006's Avatar
checkmate2006
Um the header is fine but if you remove the cat is where you can get into trouble. Opps I am contradicting myself I have no cat rut roh.
Old Jun 16, 2008 | 10:58 AM
OldRick's Avatar
OldRick
Even replacing the cat with a different cat, unless required due to damage or failure, is illegal these days.
Seems like a LOT of things are illegal these days...
Old Jun 16, 2008 | 02:07 PM
MINIFVR's Avatar
MINIFVR
Wrong.
EPA-
"As of January 1, 1988, all persons engaged in the business of automotive service and repair as well as other parties in section 203(a)(3) of the Clean Air Act, are prohibited from installing or selling aftermarket converters which have not met the criteria of EPA's interim enforcement policy entitled 'Sale and Use of Aftermarket Catalytic Converters' (published on August 5, 1986). The installation of non-complying converters by a named party will be considered a violation of section 203(a)(3) of the Clean Air Act, and the violator may be subject to a civil penalty of up to $25,000 for each improper installtion."
http://www.epa.gov/otaq/cert/factshts/catcvrts.pdf
As long as the criteria is met, then you're all set!
Old Jun 16, 2008 | 02:11 PM
Bang110's Avatar
Bang110
I'm not too worried about keeping it legal. I have the option to register it in a rural town so I would never have to smog it again.
Old Jun 16, 2008 | 02:18 PM
MINIFVR's Avatar
MINIFVR
That's the thing. According to this EPA document as long as the cat you get follows the criteria set by the EPA you are legal. I don't know what OldRick is talking about.
Old Jun 16, 2008 | 02:27 PM
Phantom's Avatar
Phantom
I would get a larnai header but thats me.
Old Jun 16, 2008 | 02:29 PM
trackster's Avatar
trackster
A header will start to make more sence as you mod the car further . If you go to a new head , cam or ported SC for example a header will be more beneficial .
Old Jun 16, 2008 | 03:35 PM
Bang110's Avatar
Bang110
So with only a cat back exhaust, Alta intake and 15% SC pulley a header wouldn't be a benefit?
Old Jun 16, 2008 | 03:48 PM
ninjlao's Avatar
ninjlao
Ninja Mini
It would still benefit. However, it would be more complementary with head work.
Old Jun 16, 2008 | 04:37 PM
OldRick's Avatar
OldRick
Well, according to Random Technologies site, a vendor of high-flow cats, the EPA says:
"Aftermarket converters may be installed in the following situations.
1. If the vehicle is missing a converter;
2. If a state or local inspection program has determined the existing converter has been lead-poisoned or damaged or otherwise needs replacement;
3. If the vehicle is more than five (5) years old or has more than 50,000 miles and a legitimate need for replacement has been established and documented."
Have a look at: http://www.randomtechnology.com/Cata...structions.htm
scroll down to the last few paragraphs.
Federal law prohibits repair businesses from replacing these devices except under certain limited circumstances, and there has to be real documentation. I doubt that the law has ever been enforced, but them's the rules, folks.
Old Jun 16, 2008 | 06:54 PM
Bang110's Avatar
Bang110
Why is it that anytime anyone posts something about moding your car there is always someone to point out thats it's illegal or you cant do it?
Old Jun 16, 2008 | 07:31 PM
british RACING green's Avatar
i'd imagine if you put a catless header on your car your car would qualify as "1. If the vehicle is missing a converter" seeing as the new header would leave the car as a vehicle missing a converter
Old Jun 16, 2008 | 08:23 PM
OldRick's Avatar
OldRick
Probably not.
And, as to Why? It's because I don't have one yet...
Old Jun 17, 2008 | 12:37 AM
silversmoke06
I have a header now.
I just dont have it put on.
Old Jun 17, 2008 | 12:42 AM
ninjlao's Avatar
ninjlao
Ninja Mini
The laws on these sorts of things can't really be enforced. The only actual crime would be to not have a catalytic converter. Coilovers are technically also illegal and are not supposed to be for street use. The only circumstance in which these products are allowed to be replaced on the car is if the original has broken or malfunctioned. That said it's very easy to come up with a story as to why these parts were replaced. As long as a CARB certified catalytic converter is welded to the header then you'll have no problems with CARB emissions/testing and the police.
Old Jun 17, 2008 | 04:59 AM
MINIFVR's Avatar
MINIFVR
+1
I know everyone here doesn't run a cat but its the right thing to do and it should be a crime.
Old Jun 17, 2008 | 06:32 AM
yellowbritishrocket's Avatar
yellowbritishrocket
oh yes they can be enforced....ive gotten the tickets to prove that it can....most states will write you a ticket for illegal ticket or illegal modifications...but in the end it depends on the state/local laws and how much they plan on enforcing....just remember one thing....you have to pay to play...if you get a ticket for an aftermarket part alot of times its not a moving violation and its a small fine
