Drivetrain Early R53 power steering fan shield
Old May 24, 2008 | 09:09 AM
jblow's Avatar
jblow
Any reason why these would not be a good idea to install on an early MCS which does not have the shield integrated into the factory fan?
Old May 24, 2008 | 09:32 AM
Guest's Avatar
Guest
Provided it doesn't block airflow to the fan, then sure, it's a great mod. Alternatively you could just install the new design shield with an integrated shield.
Old May 24, 2008 | 10:20 AM
ScottinBend's Avatar
ScottinBend
These will stop the larger items from damaging the fan blades themselves, but by far the biggest reason for fan failures is the actual design of the fan. The fan shroud itself allows water and debris to actually fall into the motor area from the backside and jam up/corrode the motor.
Best maintenance for the fan is to periodically check to make sure it actually turns by physically turning it to make sure it isn't clogged with debris. I check mine at each oil change and a couple of time in between each change.
Etrain
16
Aug 5, 2024 04:37 AM
David.R53
Sep 1, 2015 06:51 PM
JPMontes3
Aug 23, 2015 01:26 AM
azntaiji
Aug 13, 2015 03:24 PM
minipopkart
Aug 13, 2015 05:22 AM
